2wd to 4wd
Started by TLB4130, March 08, 2005, 09:32:27 PM
TLB4130
all right, well i have a 98 Tacoma 2wd 2.4L that i want to make 4wd. but i have a few questions maybe some of you guys could answer. i have herd that i might be able to just get the 4wd tail shaft and t-case. but that was only from one person. so if any of you guys have any ideas on what to do or maybe know what to do it would be tons of help that i would really appreciate.
mudaddict
t,case and a front drive shaft would work! maybe a new axle
I work At
All Pro Off Road
scheid6996
ya wut  he said, u need the transfercase, drive line, u might as well do a SAS so u need the kit, marlin makes it, its like $1400  and u get get an axle for about $200 if u find the right person, wut R u going to B doing with this truck?
Its a redneck thing
"Nobody Loves Me"
TLB4130
YA I AM GOING TO BE DOING THE SAS AT THE SAME TIME BUT I WASN'T SURE IF I HAD TO GET THE 4X4 TRANNY ALSO. I AM TRYING TO MAKE THIS TRUCK AS BUDGET AS POSSIBLE. I JUST WANT TO MAKE SURE I CAN USE THE TCASE WITH OUT USING THE 4X4 TRANNY. I WILL JUST BE USING THE TRUCK FOR SOME FUN WHEELING..
oddball
WELL I CAN TELL YOU RIGHT NOW IT ISNT GOING TO BE LOW BUDGET AT ALL, I DONT KNOW ALL THE PETICULARS BUT YOULL HAVE TO FAB A CROSSMEMBER OR GET THE STOCK TACO ONE OR SOMETHING. THEN YOULL HAVE TO GET A 4X TACO TRANNY WITH TCASE OR IM NOT SURE BUT MAYBE A W56 WILL MOUNT UP OR MAYBE A DIVORCED T CASE. MOST OF THE GUYS IVE SEEN WITH SAS TACOS RUN A D44 UP FRONT, MY DADS PRERUNNER HAS A BLOCK OFF PLATE WHERE THE T CASE LEVER WOULD COME THROUGH THE CAB SO IF YOUR TRUCK DOESNT HAVE ONE THEN YOULL HAVE TO CUT. IT WOULD BE GOOD IDEA TO SEARCH ALSO, HOPE THAT WAS SOME HELP :beer:
oddball
OH BY THE WAY IF YOU DECIDE TO DO THIS TAKE PICS :gap:  :beer:
scheid6996
ya thats wut i was gona say, thats Y i asked u wut Ur going to B doing with it, cus id jus use a D44, is it also gona B a DD?
Its a redneck thing
"Nobody Loves Me"
TLB4130
i a not relly conserened with all the mounting and fab stuff i can do all that. i was thinking that i maybe could run a older t-case. but have it divorced and run the Toyota front axle but there is just gonna be some clearance issues like it will sit too far back. i will just have to take some measurements. it is probably going to be pretty tricky but it is worth the try.
FATB0Y
:idea: you can use an early 80's Datsun transfer case it's devoiced and fairly small but strong :thumbs: I've done it If you got bench seat you'll  have to change to buckets.
TLB4130
