Author Topic: Temp Guage  (Read 1180 times)
Dirt Mover
  • Turtle Points: 186
  • Male Posts: 355
  • Member since Sep '03
  • Chrome won't get you home
Temp Guage
« on: Feb 03, 2013, 06:25:30 PM »
Swapped out the thermostat which was a chore in itself. Broke a bolt and an easy out, but anyways. Started the truck and plugged in the wire into the plug, but the temp gauge isn't working. Has to be easy, what should I be checking?
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
Re: Temp Guage
« Reply #1 on: Feb 03, 2013, 08:24:05 PM »
What year of Toyota, motor and Carb/EFI?  Cause on my 22RE, my sending unit isn't in the T-Stat housing.  It's back in the middle of the intake where it bolts to the head.
Here's a picture I stole offline.
Check to see if the wire isn't broken.  When I got my truck the sensor wire that goes to the T-Stat housing, was broke, and I had to solder and repair it.
Dirt Mover [OP]
  • Male Posts: 355
Re: Temp Guage
« Reply #2 on: Feb 04, 2013, 10:53:02 AM »
It is an 85 4runner with efi. Single wire coming out of the thermostat housing. The gauge was working before I unplugged it (reason for thermostat swap)
Cheesemaker
  • Male Posts: 4,525
Re: Temp Guage
« Reply #3 on: Feb 04, 2013, 09:02:51 PM »
I would then test the wire.  Pull it all apart and see if the wire isn't broken, mostly at the crimp for the pigtail.  Cause thats where the corrosion will start.  Just remember its 28 year old wire, it gets brittle over time.
I had bad wires in my truck, but it wasn't until I used a volt ohm meter to see the resistance, that I had a bunch of bad wires.
« Last Edit: Feb 04, 2013, 09:09:11 PM by Cheesemaker »
Last post Mar 20, 2005, 07:33:40 PM
by BigMike
Last post Jan 06, 2006, 08:22:48 AM
by 84toyota
Last post Jan 16, 2006, 10:34:37 PM
by gturismo
Last post Apr 29, 2007, 04:01:46 PM
by brainlessfool
Last post Nov 06, 2009, 04:46:33 PM
by trekkerpaul
