Built exoed 1985 4 runner
Started by chuck85, February 02, 2013, 10:28:56 AM
chuck85
1985 toyota 4 runner sr5
This truck is very maticulously built!
engine:22re was built by dave at pro machine it is a very well built long block, with brand new head,new rod,new and bigger pistons,new valve guides,rv competion camshaft,steel timing chain,rings and pistons bored .20 over all new bearings, bushings,and springs, new headers and cold air intake with 2.5 inch magnaflow exhaust. Motor has 3,000 miles on it with all paperwork!
Trans: w56
Transfer cases: duals with 4.7s in and twin sticks
Front axle: dirty thirty chromoly shafts and birfs, chromly hub gears, hyrolic assit, six shooter knuckles with arp studs! High steer cross over steering, 1.5 wheels spacers 5.29s and spartan locker, v6 disk breaks upgrade.
Rear axle: Toyota elocker swap with elocker in rear, rear disk break conversion with v6 break upgrade,5.29 gears.
Suspension: 4inch Allpro springs on all four corners, fox 14inch resivoirs on all four corners, fox air bumpstops on all four corners!
Armour: full custom exocage done by iron horse customs it is tied into arb bumper on the front and full tailgate cage in the rear.Bud built bomb proof t case cross member
other ugrades: warn 8000 winch, procomp hd lights, arb compressor plumbed and wired for on board air,red top battery, corbeau rs seats,tom woods custom 12inch long spline drive shaft,cb and cd player,half doors, cut hard top for summer.
37/12.50.15 Pittbull rockers with 90% tread and custom toyota beadlocks
All parts are brand new and have been on the truck for 6 months, all suspension is 60 days old.
This truck was built by professionals from bottom to top with all records to prove it!
undecided
HDcruiser
chuck85
chuck85
chuck85
chuck85
