Author Topic: Front End Question  (Read 1911 times)
Dirt Mover
  • Turtle Points: 186
  • Male Posts: 355
  • Member since Sep '03
  • Chrome won't get you home
Front End Question
« on: Jan 29, 2013, 05:48:52 PM »
I'm just wondering what everyone is running for steering arm studs.
I'm running Marlin arms, the old All Pro spacer with longer studs, 37" Iroks on 10" wheels with 3 1/2" of backspacing. On MLK Jr. weekend I think my trunion bearing failed first while wheelin and I broke the studs. Had all the parts to fix, but I'm looking to rebuild both knuckles and carry spares. So what is the hot set up ?
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: Front End Question
« Reply #1 on: Jan 29, 2013, 05:51:38 PM »
I like the 5th stud mod. Looks beefy
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
« Reply #2 on: Jan 29, 2013, 06:40:49 PM »
I ran arp's for years and never had an issue. but would tighten then at least once a day on the trail. Now I run 6 shooters and trunion elims and have never had a prob either.
You'll never take me alive
Dirt Mover [OP]
  • Male Posts: 355
« Reply #3 on: Jan 29, 2013, 06:54:31 PM »
I've been looking at the eliminator set up. How often do you need to grease it? The extra width is probably a big part of the problem and cleaning bearings out of the birf is a dirty job on the side of a trail.
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #4 on: Jan 29, 2013, 07:37:37 PM »
Here is a good write up from someone who has run them for a while. I grease them every other trip. but that may be overkill.
http://www.pirate4x4.com/forum/toyota-truck-4runner/868840-trail-gear-trunnion-bearing-elim-kit-install.html
cencalwheeler
  • Member since Jan '11
« Reply #5 on: Jan 29, 2013, 07:44:29 PM »
I run the six shooters with arp studs. I check them regularly but they are never loose.
87 money pit....
Dirt Mover [OP]
  • Male Posts: 355
« Reply #6 on: Jan 31, 2013, 08:19:31 PM »
Ordering the eliminator kit and ARPs. If it doesn't hold up the six shooter will be next, but I'm thinking I'll be good.
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #7 on: Jan 31, 2013, 08:57:05 PM »
Good call. Just make sure you torque the studs religiously.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #8 on: Feb 01, 2013, 07:37:44 AM »
Most people that generally have issues, tend to forget this step.
I've also read posts about how some people have broken six shooters too!!
mudmaster
  • Turtle Points: 3715
  • Male Posts: 2,854
  • Member since Feb '05
« Reply #9 on: Feb 01, 2013, 09:08:48 AM »
All Pro arms with ARP studs. I check the torque before every run. I've never had an issue .
Time to go wheelin!
Dirt Mover [OP]
  • Male Posts: 355
« Reply #10 on: Feb 04, 2013, 10:58:41 AM »
I carry a 17mm wrench in the consol for this reason, check the studs at air down. We went wheeling in the desert and I think the high speeds on washboards is what took it out. With the price of the kit with ARP's I'll definitely be watching them.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #11 on: Feb 05, 2013, 07:28:50 AM »
Unless they have changed the eliminator kit will not work on the Marlin arms without some modifications made. The pin on the TG kit are 3/4 inch that press into the arms, the holes on the arms are 1 inch. You will need to have some reducer bushings made and pressed into the arms in order to press the eliminator into the arms.
Dirt Mover [OP]
  • Male Posts: 355
« Reply #12 on: Feb 05, 2013, 12:16:47 PM »
Good to know. Hopefully parts will be here today. I'll be looking for a machine shop in Bakersfield if that's the case.
Dirt Mover [OP]
  • Male Posts: 355
« Reply #13 on: Feb 06, 2013, 03:55:38 PM »
Oops is corect that the pins are different. I'll be trying the bearing house by work to see if they have something that will work first. I'll post the part # if I get lucky.
Dirt Mover [OP]
  • Male Posts: 355
« Reply #14 on: Feb 15, 2013, 09:45:37 PM »
Back from the machine shop. Left the bushing long so I can put a normal zerk in it and be protected.
Cheesemaker
  • Male Posts: 4,525
« Reply #15 on: Feb 16, 2013, 07:35:19 AM »
 :thud:
specialscottie
  • Turtle Points: -1
  • Member since Aug '10
« Reply #16 on: Feb 24, 2013, 06:31:08 PM »
Im running arp studs. Havent had any problems yet
Last post Feb 16, 2005, 05:39:12 PM
by Hyena
Last post May 23, 2005, 05:29:14 PM
by MiniSimp
Last post Jul 06, 2005, 09:52:18 AM
by BirdDog
Last post Aug 24, 2006, 06:42:02 PM
by Ewong
Last post Aug 27, 2006, 09:42:13 PM
by want2crawl
