1992 Toyota Crawler Full Width/ARB/Detroit/a/c/5.38s $9000 SOLD Please delete
Started by fullwidthyotaon40, January 27, 2013, 12:51:02 PM
fullwidthyotaon40
Located near Santa Rosa, CA in 95462 Monte Rio
Finally deciding to post my toyota rock crawler. I rarely use it for what it's intended to do and have basically been storing it since building it. Almost every part added is brand new with receipts for most of it and it is all professionally done and built to go anywhere! Its built off a 2wd toyota frame/body for cheap insurance/reg. Brief list includes:
Front axle:
- D44 full width 8 lug new ARB air locker & 5.38 gears w/ warn hubs (one warn needs replacing)
Rear axle:
- D60 8 lug with new detroit locker & 5.38 gears
- Extended and balanced drivelines front and rear (have receipts)
- ARB is all hooked up with clean switches in the cab and compressor mounded under hood
- Chevy 1 ton brake system & master cylinder
- Power steering added and IFS converted
- Sky mfg. full width front hanger/shackles
- Custom rear dual shackle (yodaman)
- Rear Procomp extended 5" lift springs for full widths (yodaman)
- Dual Cases (Marlin Crawler, the best!)
- Marlin Crawler 4.7 gears in rear case (built by Marlin as well)
- W56 manual 5spd transmission
- 22RE engine (200k on body, frame down new)
- Front and rear frame reinforcements
- 14" Bilstein shocks and new hoops rear AND front
- 40" TSL Boggers on weld rims
- All Pro dual case skid plate & high clearance crossmember (rear tcase mounted)
- Full size 40" bogger spare on MTR beadlock 8 lug
- Full skymfg. histeer with flat top knuckles
- Custom welded 1/4" front and rear diff covers (match)
- Working A/C separate from arb air system! r134a
