Rear third member 5.29 with spool locker
Started by Toyotahilux80, January 03, 2013, 10:26:04 PM
Toyotahilux80
Hi noob here I'm getting ready to change my rear third member for  a brand new complete third with a spool locker, this will be my first time I'm wondering if theres any pointers anyone can shoot me I'm confident I can manage but like I said it's a first anything helpful is appreciated! :help:
IF IT AIN'T BROKE FIX IT TILL IT IS!
tgmaul88
pull the shafts   pull the third,      put the new third in with minimal sealant,  put shafts back in, bolt up and run it
OOPS
1.   Drive around a bit to get the gear oil warmed up, will drain faster.
2.   Set on jack stands and remove tires and brake drums.
3.   Drain gear oil.
4.   Disconnect e-brake cables and brake lines, plug the brake lines.
5.   Remove the eight nuts holding the axles in.
6.   Pull the axles out of the housing.
7.   Remove the four nuts and bolts holding the d-shaft to the diff. If they have never been removed before the may still have the factory thread locker and will be very tight. Heat the nuts with a propane torch a bit to soften the thread locker. Mark the d-shaft and flange so you can put it back in the same spot you removed it from
8.   Remove all the nuts and lock washers holding the diff to the housing.
9.   Pull the diff, it may be stuck, put a small jack up by the flange and jack up the front of   the diff a bit to break the seal.
10.   Install in reverse order
11.   Now would be a good time to change the axle seals.
12.   Bleed the brakes and fill the diff with gear oil.
13.   Have fun driving a spool on the street and wearing out your tires.
Toyotahilux80
stihlmohawk
Hey nick.. you can always bring it by my house and we can knock it out in about an hour... :beer:
.....If you loose in life its because you lag.....
