Swapping an auto trans out for a 5 speed in 91 4Runner
Started by dingleberry87, December 19, 2012, 06:21:46 PM
dingleberry87
I'm trying to gather some input for my brother. He currently has an automatic trans in his 4Runner with the 3.0. I myself know a little about our Toyota's but don't know a whole lot like some of you gurus out there. What all is needed to do the swap?
He currently has-
5 speed trans w/ t case
Clutch pedal assy
Clutch slave and master cylinders
Hydraulic clutch line
Cross member
For some reason I wanna say that we'll need manual locking hubs because his currently has auto locking hubs. I'm sure there's a lot more missing and was hoping for some help. Thanks guys
the hubs will do nothing really without changing the whole front center axle assembly to a non auto locking section.
otherwise the parts you have listed, sounds like hes got what he needs.
2009 i did this to a 90 4runner with a 91 5spd swap. i went all out and swapped entire body harnesses. what a PITA, you can do it with just looping the park/nuetral switch and splicing the reverse light wire.
Vang530
a bi-metal hole saw (i forget what size i used) and a right angle drill would have helped make things easier (can just use regular one).
having a separate parts truck is much easier and was what i did.
Oroville, CA
Quote from: Vang530 on December 19, 2012, 10:12:36 PM
Having a parts vehicle made a world of difference. And yes a drill for the clutch master on the firewall
Sent from the HO KID network using Tapatalk 2
UndefinedTaco
R150f
New clutch
Clutch pedal
Slave cyl
Master cyl
5 speed crossmember
5 speed driveshaft
83' Pickup "ShitBox" - more parts
92' Pickup "Doomed" - some parts
dingleberry87
Sweet thanks guys. I think I'll be starting that project for him this weekend. Wish me luck lol
Quote from: dingleberry87 on December 21, 2012, 09:41:22 PM
no problem. chime in, if you need help or have questions.
dingleberry87
Cyberman
You probably already have the clutch switch.  Another bonus would be the clutch start cancel switch, for starting on hills and such.
Sent from my DROID RAZR using Tapatalk 2
'91 Xtra cab 3.0 SAS, 5.29s, single 4.7 transfer, locked f/r, 35s
My Frame-up Rebuild Thread
Quote from: Cyberman on December 22, 2012, 02:06:14 PM
that requires more wiring lol or swapping of the whole harness.
dingleberry87
UPDATE: before pulling trans, we did a compression test just for the heck of it and found cylinder #6 was dead :(
So now we gotta do an engine n trans project lol
Cyberman
Quote from: dingleberry87 on December 28, 2012, 06:37:30 AM
may as well do a 3.4 swap while you're at it.
Cyberman
Quote from: THK Matt on December 28, 2012, 11:34:54 AM
X2
I replaced mine with another 3.slow,  but when this one goes it'll have a 3.4.
