s10 trugy crawler.203/205 doubler.propane.v8sway aways.tonzzz has dig
Started by crawlerbubba, December 16, 2012, 08:39:31 AM
crawlerbubba
truck has current tags,and is registered as a 75 chevy...so no smog needed.400 hp 350.msd billit pro dist.msd 6al ign box.pete jackson gear drive.ceramic coated headers.h beam rods.flat top pistons.propane kit.th 350 tranny.1410 u joint d/l.203/205 doubler from north west fab.has front and rear dig.dana 60 .4.56 gears.welded.14 bolt.4.56 gears,detroit.shaved.trussed.disc brakes.has ballastic heims.ballastic hi steer arms.psc ram.red nek ram p/s pump.taurus fan.3 linked.2.5 sway aways.18 inch travel.new master cylinder.25 gal propane tank.full exo.cust buckets.b&m shifter.tach w/ shift light.5pt harnes.flat belly.42 in swampers.bart wheels.9000# winch.clocking ring for rotating rear t case.flowmasters.billit alum p/s cooler.edelbrok intake.price drop...$8000. OBO.trade for a tacoma 4x4 xtra cab.2000 or newer chevy/gmc xtracab 4door......diesel dodge or ford.2/4 wd.cash and trade?open.530-526-1006.located in red bluff.way nor cal.**added a TK 1 sway bar(same as anti rock) kit to rear axle to reduce body roll,and force traction.wheels even better now.just ordered off road designs tripple stick to be able to do dig!shift rail mods been done already.....just ordered weld on bead lock kit....**sold**
GOT ROCKS?
crawlerbubba
GOT ROCKS?
86moneypit
Send them to me Ill post them.  As long as they are under 140KB then we should be good to go.
Sorry couldn't help with the pics man.
86 Runner 529s locked duals 37s
96 Runner 5sp. 3.4 32s DD
04.5 Dodge 2500 CTD With Go Fast Stuff On It
Drive it like you stole it
crawlerbubba
GOT ROCKS?
crawlerbubba
day after christmas bump.
added a tK 1 sway bar(same as anti rock)to rig ....handles better,and lot less body roll......
GOT ROCKS?
crawlerbubba
just ordered off road designs tripple stick shifter set up.shift rail mods for  dig already been done......
GOT ROCKS?
crawlerbubba
installed the off road design Triple stick shifters today.did works great,they are great shifters...
GOT ROCKS?
crawlerbubba
GOT ROCKS?
