84 toyota extra cab 22RET SOLD
Started by GhostMoney, December 10, 2012, 09:44:25 AM
GhostMoney
Selling my 84 Toyota 22RET crawler. SOLD Truck is located in Salem, Oregon
Motor:
22 RET – unknown miles (speedo has not worked since I purchased it)
Has run flawlessly since I purchased it though
Transfercase:
Dual Cases
23 Spline
4.7 gear in rear case (Marlin) with only one trail run on them
Front Axle:
4.10 Gears
Lockright
Chromo Hub Gears
ARP Knuckle Studs
5th Stud Mod
Longs
Trail-gear Diff Cover
Square Tube Drive Shaft
Rear Axle:
4.10 Gears
Welded
Trail-Gear Diff Cover
Stock rear drive shaft
Tires:
38 TSL's Grooved with decent tread
2 spare 38's with rims
Spares:
Square Tube rear drive shaft
v6 third
4cyl third welded
Truck has no bed and no doors. Has some dents under both extra cab windows from removing exo. $3000 OBO (does not come with winch)
Truck is Located in Salem, Oregon
Picture with bed still on, will be repainting truck this weekend.
GhostMoney
Price drop to $2600 final price drop before part out.
MAGIC
Interested in truck. How many miles on the motor. I know the Od  doesn't work but you should be able to estimate at least what you put on it. I would guess the speedo doesn't work because the engine is not stock for 84 so when whoever put the RET in he didn't update the gauge cluster for computer.
Thanks.
GhostMoney
I will get you the mileage after work today. I have owned the truck since I believe spring 09 and I have put no more than 5000 mi as I only drove it for couple months then it became a trailer queen.
GhostMoney
lone walker
My understanding with 22rte engine is from '85 to '88 only and on selected model.
Is the engine changed?
Going, going, gone
GhostMoney
Sparkplug
