Help me diagnosis transmission problem
Started by OLDYELR, November 10, 2012, 10:04:37 AM
OLDYELR
I have a W56 A or B transmission that make some bearing noise when idling or when clutch is not engaged. When I push the clutch pedal pedal in the noise goes away slowly like a bearing rotation noise. Would that be some sort of clutch bearing or a main shaft transmission bearing?
Also is the transfer case shafts spinning when in neutral idling?
finisher424
is the clutch fork secure? i had same problem and what happened was the clutch fork retainer snapped and was rattling around until i pushed in clutch
