V6 brake calipers
Started by dingleberry87, September 23, 2012, 08:38:14 AM
dingleberry87
Quick question: do V6 brake calipers bolt right up to a 4cyl? I have a 3rd Gen 4cyl that's getting new calipers soon but just wanted to know if the V6 ones bolt on or if there was some Fab involved. Thanks guys
Bolts right up in ur application.
Sent from the HO KID network using Tapatalk 2
dingleberry87
junya92toy
No they wont bolt up to a 4cylinder, thats a engine ;)
Quote from: junya92toy on September 23, 2012, 01:03:07 PM
Ur such a smart ass. Lol
YELLOZOMBIE
I recently installed v-6 calipers on mine and I had to trim a little off the backing plates. Hopefully you don't have that problem.
If its ifs to ifs, shud be no prob. Of its ifs to SA, then i can see trimming, but most dont run backing plates on their solid axle.
YELLOZOMBIE
You're right Matt, I should have ran it without backing plates. My trucks kinda  :stopit:
junya92toy
I cut mine down so its just got the brake line holder
OOPS
#9
I cut the circle with the bolt holes and just run that. I cut the brake line bracket off anddrilled a hole in it, the caliper bolt holds it in place. This way I do not have to disconnect the brake line from the caliper when I want/need to get into the front end.
V-6 calipers bolt right to a Toyota SA but you need/should run different rotors. I think the rotors I used were from a FJ-60 Landcrusier I think, do not remember I did it in 1999!!!! :reg:
