is there a complete kit for rear chevy springs somewhere out there?
Started by 907yota, August 24, 2012, 02:16:05 PM
907yota
Hey all,
I just scored some rear 63" chevy springs... is there a complete kit that i can order for this swap? i saw a couple companies out there but none of them seem complete w/ everything you might need...which brings me to my next ?... can anyone put a list together with everything i need for the swap.... please and thankyou
P/s
ive never done this before just helped a buddy install marlins rear kit w 4" springs
907yota
86 reg cab turbo,99runner,95pickup all 4x4
09 honda rincon 680cc 4x4
2000 yamaha badger 80cc (for the kids)
Chicken nutt bread!!!
OldGold3VZE
Sky manufacturing makes one, but this "kit" can be made easily at home with a foot of 3.5" x 3.5" .250" wall square tube and an angle grinder and a drill press.  Cut the square diagonally with your angle grinder leaving a 2-3" flat spot on either end, then slice off the bottom, and drill holes.  It's really easy.  If you don't have shackles, just cut up some 3/8" x 2" strip steel and drill holes.  It's an afternoon job if you're motivated.  I think I have some pics in my build thread.
My 1980 Long Bed build thread
http://board.marlincrawler.com/index.php?topic=84562.0
Truggy build thread
http://board.marlincrawler.com/index.php?topic=89844.0
Rastafari Livity!  Ital = Vital!
907yota
thanks guys, i searched but thought maybe somone would know of a specific company that would have a complete kit with everything needed...peterbuilts thanks for the search those never came up when i did it
Cheesemaker
907yota
thanks cheesemaker
I just scored these 63's for 20 bucks there a little rough but not pitted or anything.... the bushings look like their not coming out without a fight, is there an easy/better way to remove these without breaking out a torch?
OldGold3VZE
Truggy build thread
fordh8r
Quote from: 907yota on August 25, 2012, 04:12:42 PM
  I use a hole saw just bigger than the inner metal sleeve to cut through the rubber. Then with an air hammer, you can knock out the shell from the spring eye using a chisel bit while running it along the spring eye's groove (where the end of the leaf wraps back around and contacts the spring again).
When you go to install it, I use a long piece of all thread (preferrably as big as will fit through the new bushing) with some large washers (or a metal plate that spans the spring eye opening) against the spring eye opening and a socket that fits over the edge of the rubber of the new bushing and contacting the metal shell of the bushing with nuts at both ends of the  all thread and just run it down. The new buishing will slide right in and it"s self aligning as you go. Use a little anti-seize on the shell of the new bushing too. Hope that helps.  :beerchug:
907yota
Quote from: fordh8r on August 25, 2012, 07:38:18 PM
thanks fordh8r,
i was told to just use a torch and burn um out, but your way sound easier on the springs...ive been collecting these parts for some time now but still have a ways to go...cant find anything in my little town, craigslist has been my freind..should i rebuild these with new slipper sleeves or just leave the stock ones in there after i paint them
fordh8r
Quote from: 907yota on August 26, 2012, 10:32:00 AM
thanks fordh8r,
  Right, I've never been a fan of putting flames to springs myself.  :nope:  Even if the flame is concetrated on just the bushing. Plus, that :pokinit: STINKS forever!  :ack:  I discovered this method when I was a broke  :moon: , I never had a torch available to me, so I used what I had and it seemed to work nicely. Sometimes you have to come from both sides with the hole saw to get it out completely but it will come out.  It's still a little stinky but not nearly as much.  :gap:
  I had a buddy whose poorly routed exhaust had burned his bushing away and we were able to change his out while on the truck in about 15 minutes. But not before he had his exhaust rerouted as to the cause for changing the bushing in the first place. Granted, the rubber was already gone at that point, but that just saved us one step.  :thumbs:
Peterbuilt84
Not sure if you have access to a press, but that would probably work pretty good.
85runner_
I just left the bushings in. Mine weren't that bad. The hole saw idea seams legit
