Author Topic: whats my crawl ratio?  (Read 4433 times)
toygasm
  • Turtle Points: 31
  • Member since Dec '08
« on: Aug 24, 2012, 09:24:12 AM »
i was showing a guy how slow my truck is and he asked me what the crawl ratio was.i wasnt sure and really never gave it much thought.i just watched the video of big mikes truck doing his slow motion brake stand and it got me wondering....ive got a marlin built w56,marlin duals 2.28/4.7 and 529s..obviously a very common setup.
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: whats my crawl ratio?
« Reply #1 on: Aug 24, 2012, 09:39:36 AM »
Hey toygasm,
Calculating your Crawl Ratio is a matter of knowing each gear reduction between your engine and your tires and then multiplying them together.
Transmission:
To check what gear ratio your have, use our chart here: http://www.marlincrawler.com/tech/transmission/transmission-gear-ratio-chart
Your W56 has a 3.95:1 first gear.
Crawl Box:
Your Crawl Box is the 2.28:1 unit
Transfer Case:
T/Case has the 4.70s
Axles:
Axles have 5.29:1
Crawl Ratio:
Transmission X Crawl Box X Transfer Case X Differential  =
3.952.284.705.29= 223.91:1 or 224:1 Final Drive (or Crawl) Ratio.
You've got what we call the Ultimate Ratio which you can read more about here: http://www.marlincrawler.com/java/ultimate.html
Here is another example of what your Crawl Ratio is in 2nd gear:
2nd gear X Crawl Box X Transfer Case X Differential  =
2.142.284.705.29= 121:1
And continuing, we see your 5th gear is 48.2:1 which is what your truck was before the Marlin Crawler, 47.6:1. So our Marlin Crawler turned your old first gear into your new fifth gear!! :o :love: :turtle:
We have an old online Crawl Ratio Calculator here that you does all the calculations for you: http://www.marlincrawler.com/java/getratio_calc.html
...and we also have an old Vehicle Speed Calculator here: http://www.marlincrawler.com/java/getspd_calc.html which you can enter your tire size and engine rpm (assume 800 rpm for idle speed) to see how fast your truck is actually moving.
The Vehicle Speed Calculator shows that Marlin's truck moves 0.0641 miles per hour in first gear, or 15.6 hours per mile!!
:beerchug:
« Last Edit: Aug 24, 2012, 10:16:43 AM by BigMike »
  • 511:1 Club
« Reply #2 on: Aug 24, 2012, 10:18:08 AM »
I just updated the Vehicle Speed Calculator to show the MPH inverse which is HPM. I haven't updated that file since I think the 90s!! (I made it while I was still in high school). I used Javascript and I hate Javascript. I'm much better at PHP... I think I may have to create new modern versions of these Calculators :) :) :)
* BigMike thinks about how much stuff he has on his todo list
toygasm [OP]
  • Turtle Points: 31
« Reply #3 on: Aug 24, 2012, 10:30:45 AM »
thanks for the info.
dweinberg01
  • Turtle Points: 122
  • Member since Jan '07
« Reply #4 on: Aug 24, 2012, 12:25:04 PM »
Does anyone know what first gear for an A340h is?  I know you double it because of the torque converter then go about multiplying as you go back.  I just can't find my trans 1st  gear. thx
A340h first gear x marlin dual ultimate x 4.88 r&p = ~340:1 I'm thinkin.
« Last Edit: Aug 24, 2012, 12:36:26 PM by dweinberg01 »
TimberlineBryce
  • Turtle Points: 517
  • Male Posts: 538
  • Member since May '12
    • Timberline offroad
« Reply #5 on: Aug 24, 2012, 01:04:06 PM »
This is so awesome!! Where do I find my R150f trans 2nd thru 5th gear ratios??
See you at the Timberline!
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
« Reply #6 on: Aug 24, 2012, 01:16:43 PM »
That's fun to play with.
  • 511:1 Club
« Reply #7 on: Aug 24, 2012, 04:38:34 PM »
Lately I've been using Wikipedia for automatic transmission ratios. Check here: http://en.wikipedia.org/wiki/Toyota_A_transmission#A3xx They are not all listed but it should be a good place to start.
This is correct. I've heard Torque Converters range from 2:1 to 2.5:1 reduction.
Clicky: http://www.marlincrawler.com/tech/transmission/transmission-gear-ratio-chart
dweinberg01
« Reply #8 on: Aug 24, 2012, 04:50:01 PM »
This is what i got: 366.05856 :1.  Not bad!!! Thanks for the info BigMike
« Last Edit: Aug 24, 2012, 04:56:59 PM by dweinberg01 »
  • 511:1 Club
« Reply #9 on: Aug 24, 2012, 04:55:21 PM »
That is incredibly great for an Automatic! I bet you have trouble stopping it sometimes even!! :driving: I love it!!!
TimberlineBryce
  • Male Posts: 538
« Reply #10 on: Aug 25, 2012, 10:38:31 AM »
So if I did the math crrrectly, when I put the single 4.7 t-case in, my first gear should be about double what my stock first is now and my 4.7 5th gear will be about halfway between my stock second and third gear(which should be perfect for cruising the easy stuff). This is exciting because I was worried I wouldn't be happy with this setup like everyone has been telling me but with using the math it sounds like it'll be exactly what I'm looking for;)) :thumbs:
  • 511:1 Club
« Reply #11 on: Aug 27, 2012, 11:04:57 AM »
Here are some prehistoric videos comparing different Crawl ratios:
http://www.marlincrawler.com/video/index.php
TimberlineBryce
  • Male Posts: 538
« Reply #12 on: Aug 27, 2012, 12:51:39 PM »
Hey Mike how did you get 511:1?? And what gear ratio do you find yourself using most often on the trails around here??
TimberlineBryce
  • Male Posts: 538
« Reply #13 on: Aug 27, 2012, 01:05:07 PM »
My first gear final will be 82:1 which I think will be ok for most "on-trail" wheeling in this area... :dunno:
« Last Edit: Aug 27, 2012, 02:25:50 PM by TaroVr6 »
  • 511:1 Club
« Reply #14 on: Aug 27, 2012, 01:20:13 PM »
3.95:1 W56-A transmission > 2.28:1 Crawl Box > 2.28:1 Crawl Box > 4.70:1 Transfer Case > 5.29:1 Differential: 510.53:1
I just got back from Dusy and we were jamming most of the time because we were short on time (went from Thompson Lake back to the Pavement at Courtright in 2-1/2 hrs).
On the easy sections I was in single 2.28:1 using 1st-3rd gears.
On the moderate sections I was in Dual Stock 2.28 + 2.28 using 1st-2nd gears.
On the difficult sections I was in Dual Ultimate 2.28 + 4.70 using 2nd-4th gears (Out of luxury, I never use Dual Ultimate 1st gear, I explain why below).
And twice I needed really precise control so I used Triple Ultimate 2.28 + 2.28 + 4.70 and 2nd gear (I used it while coming down Thompson when I had to backup; I used it near Dusy Meadows when a rock got wedged between my beadlock ring and my hub). I never used any other gear in Triple Ultimate.
The gears I use most of the time on our local trials would be Dual Stock 2.28 + 2.28 using 1st - 3rd gears. I only shift back to a single 2.28 if I am using 4th or 5th gear in Dual Stock (because it's pointless to spin the transmission that fast when I can just simply shift back to a single 2.28 case).
My overall favorite gear ratio I have, regardless of the trail, is Triple Ultimate 2.28 + 2.28 + 4.70 in 2nd gear. This gear (277:1) is about 25% lower than a Dual Ultimate's first gear (224:1) and that little extra bit allows me to lug down to about 400 rpm without stalling the engine. I almost never use my Triple Ultimate 1st gear. It is my only novelty gear ratio and I only use it to demonstrate the power of the Marlin Crawler.
« Last Edit: Aug 27, 2012, 01:29:30 PM by BigMike »
TimberlineBryce
  • Male Posts: 538
« Reply #15 on: Aug 27, 2012, 02:30:51 PM »
Lol "novelty gear"!! I like that! :biggthumpup: ok good info, thanks! :thumbs:
ImmortalYota80
  • Turtle Points: 12
  • Male Posts: 419
  • Member since Aug '12
« Reply #16 on: Aug 31, 2012, 01:14:57 PM »
This was helpful
1980 4x4 Pickup, 22RE Swap, Marlin Built G54 Trans, 35/12.50 Cooper STT's, 4" Alcan Front springs/F150 rears, Open 5.29 front, 5.29 E-Locker Rear, Rebuilt Axles, High Steer
Build:
http://board.marlincrawler.com/index.php?topic=94416.new#new
Last post Feb 23, 2004, 09:34:30 PM
by Rockcrawlintoy
Last post Jan 07, 2005, 11:40:40 PM
by billy hill
Last post May 15, 2005, 08:45:32 AM
by 1Bad4Runner
Last post May 30, 2006, 10:42:02 PM
by 95Toyota
Last post Mar 26, 2011, 02:20:12 PM
by Axlesnap
