Crawl ratio
Started by Thumper, February 22, 2004, 09:09:34 PM
Thumper
I was wondering what will my overall crawl ratio be with a 350 chevy v8 with a 4x4 turbo 350 too duel marlin crawler 2.28 cases with 4.11 high pinions f/r :headscratch:
and then with a 2.28 and a 4.7 in the rear case.
Thanks marlin
The crawl chart is on the main page.  I think its in the transfer adapter page.
WT
84runner
What is the first gear ratio in the tranny?
Thumper
I dont know ill ask my friend its his truck we were just argureing on how low its gonna be and i know he is wrong he was saying like 150 or more too one.
88runner
th350 1st speed=2.52:1
so 2.52*2.28*4.11= 23.61 crawl ratio
and
2.52*2.28*4.7*4.11= 110.99 crawl ratio
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
Thumper
Hey thanks runner that seems like a really low number for haveing duel transfer cases but i guess with the auto it will help a littlebit with rockcrawling.
Thanks guys
adam
Marlin
Quote from: 88runner on February 23, 2004, 02:01:35 PM
and
Great job 88runner :bowdown: :bowdown: :bowdown:
Not counting the 2:1 ? torque converter.
Rockcrawlintoy
my buddy is about 150:1 with an auto with out the TQ. he has 4 wheel disks and has problems stopping. remember that when you get it done.
drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
