Transfer case is exploding oil PLEASE HELP!!!!
Started by yotadork83, August 18, 2012, 01:58:57 PM
yotadork83
I built my dad a custom 79 pick up. I have just upgraded the transmission to a w56 installed duals with 4.7 and rotated it up for a flatbelly. I have a F.R.O.R. twin stick on the rear case and now when i drive for awhile the t-case builds so much pressure inside it starts blowing gear oil out of the top of the twin stick rubber boot. not sure if i built the t-case wrong or something. Any helpful tips would be greatly appreciated....
yotas 4 life homie!
82rustbeast
yotadork83
just checked the breather its all good and free flowing. i noticed that i never installed the thin metal shifter shroud that goes underneath the shifter plate going to try that and see what happens.
yotas 4 life homie!
Cheesemaker
Quote from: yotadork83 on August 18, 2012, 02:27:35 PM
:thumbs:
Goldrush
U absolutely need that oil slinger! If not it will do exactly that, puke oil everywhere! Give us a call or order one online! ;) thanks!
yotadork83
yep installed that oil slinger and it fixed the problem. thanks for the help delete post if not needed.
yotas 4 life homie!
