SOLD. SOLD. Toyota pickup 3.4/sas/duals
Started by Bradtoyotas, August 14, 2012, 02:57:03 PM
Bradtoyotas
Sold
Toyota pickup 3.4 swapped... (Update)Fully wired obd2 works check engine light works like it should.. cat., o2's, charcoal all there, this thing should pass emissions to the 2000 4runner specs that the engine and parts came from...
-Engine is 3.4 v6 out of a 2000 4runner
T-100 oil pan/dipstick conversion
New timing belt
Water pump
New clutch
-Front axle is a 85
high steer
marlin 5" springs
marlin bilstiens front & rear
Land cruiser rotors and ifs outter assembly
rear has chevy 63 springs
lowrange hanger kit
4.10's axle gears
Dual transfercases
Marlin dual adapter
Marlin v6 to gear driven case adapter
a/c works
all guages work
Tires 33/12.5/15 km2's with 90% tread
Drivers seat has ussual tears, dash has cracks and passenger rocker panel has a little rock rash truck has only been out wheeling a few times no driveline vibrations from front or rear. When i installed engine it got fuel pump, fuel pump bracket..Ive invested tons of hours on this truck spent alot more than im asking make a good daily driver.. This was origonally a 2wd truck i have changed front clip to 4wd but i still have all the 2wd parts to go with it
Asking 7500$ obo st george ut about a hour from vegas
Selling to get something bigger Trades i may be interested in a cummins maybe a 4 door powerstroke
Tonka Toys
tgmaul88
Toy-Cra-Ze
Bradtoyotas
Thanks guys!!
This thing is fully wired 100%  OBD2 works... had to change a oxygen sensor and it cleared that code runs excellent..
Check engine light comes on when you turn the key and shuts off like its supose to after start. should pass emissions/smog as a 2000 4runner
Tonka Toys
builttoabuse
toy obsessed!
Bradtoyotas
Tonka Toys
ajordan1975
roadrunner2432
