o2 sensor on 1987 22r
Started by woodyth, August 03, 2012, 08:38:42 PM
woodyth
Total noob question but,
Where is my o2 sensor. I have a 1987 4x4 with a 22r and I cannot for the life of me find it. My header i ordered has the hole for it. I looked up one side of my exsaust and down the other side and to no avail It's not there. Where does it plug into? where does the wire feed into. could they bypass it somehow? and if I don't have one, what can I do to this header to make it work. it's a doug thorley 550-y-c. it's the one that is suggested according to their website for my truck. I really don't want to go through the hassle of sending this one back since they don't have anymore instock and could be months before they get one. HELP
Woody
woodyth
emsvitil
The stock O2 sensor is on the exhaust manifold just above the flange the connects to the front stock down tube (short Y to single pipe)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
woodyth
well if that is the case, I do NOT have one and need to fashion a block off plate for where it should go in the header.
Ideas?
YotaNate
Lowes will have threaded plugs in several types of metals.  I'm not sure what would work best as far as expansion and contraction but I would be inclined to try Stainless for obvious reasons.  Hope that helps.
-Nate
"A CNN reporter, while interviewing a Marine Sniper asked.  What do you feel when you shoot a terrorist"?
The Marine shrugged and replied, "Recoil."
woodyth
I just decided I was gonna spend the $20 on a new o2 sensor and install it and cut the wire close to the sensor so it isn't hanging! I suppose this will be confusing for the next owner but I will know the truth LOL
lone walker
Ha, a bung plug will only 10 buck.....
just my .02
Going, going, gone
konarider1993
before you do all that look under the drivers seat.  literally under the cab directly under the drivers seat.   some in 87 and 88 were there.
Estysalinas
If its a fed 22r it may not have one ( at least that is the way it was for 83)
