Grizzly lockers and a every day driver?
Started by Hurricaneinmotion, July 08, 2012, 07:59:34 PM
Hurricaneinmotion
 Anybody using these in an every day driver. My daily mileage is between 150- 250 a day.
I have a 1982 p/u sr5 longbed. With 22 r and 35" tires. Will these hold upto the abuse on the daily
Driver. Or will this be a high maintenance item due to my driving situation?
We make a living by what we get, We make a life by what we give.
2manytoys
I'm running Aussies in my daily driver no problem. Ran Detroits also. Just have to adjust your driving style a little. No problems after thousands of miles. I know you asked about a Grizzly but, these are still lockers.
Cheesemaker
Hurricaneinmotion
Nimyad
I run a grizzly in the rear, way better for DD than the lock right I had before. I'd recommend it, just try to coast around corners or learn new ways to use your clutch
konarider1993
You drive a looong ways to work. I have a grizzly and its great but i only have 10 miles to work
hansi530
just weld the rear its cheap and works great
88 custom cab: http://board.marlincrawler.com/index.php?topic=88026.new#new
shitlbuffout-A saying among 4x4 and off road enthusiasts. Its said after damage normally cosmetic to minor parts damage has occurred on there rig or vehicle. Shitlbuffout is :pokinit: will buff out as in the :pokinit: being the damage will buff as in painted over cleaned polished or "buffed" out.
konarider1993
i had welded spiders but burned up tires and decided i need locker
