Also Need Help ASAP!!
Started by firekiller, February 26, 2005, 05:54:49 PM
firekiller
 :confused: Wifes 2001 Runner has day time running lights that will not go off.  If someone has a FSM for this or similar Runner please help me troubleshoot this.
Thanks
Tico
:beerchug:
i have seen some that stay on for about a minute after you have turned the key off and shut the door, :dunno:
firekiller
The problem with these is that they are staying on forever.  When I pull the relay and the fuse the headlights quit working.  Not sure if there is another relay hidden somewhere else other than the one under the kick panel on the passenger side.  According to the parts guy at the stealership there is.  I just can't seem to find it.
Tico
:beerchug:
firekiller
Found the main relay, under the drivers side dash not passenger as shown in the parts guys diagram.  Anyone have any other sort of info on this situation or maybe a way to check this relay using a multimeter?
thanks
Tico
:beerchug:
