What gears are in my truck
Started by santa cruz crawler, June 21, 2012, 04:23:29 PM
santa cruz crawler
Hello , I'm no nOob !
I have found little on how to find out what gears came stock in thaw truck by what code u have in yor door!
So here's mine , What gears do I have
Thanks
That tag is not the one that tells you the axle information, the one under the hood against the firewall is the one to look for that. Use the link below and it will give you everything you want to know.
http://www.4x4wire.com/toyota/faq/vin/
santa cruz crawler
  :thumbs: cool I'll take a look ! I hope this thread helps out some more people.
Thanks
santa cruz crawler
So mine was crinkled in a reck , the only vin I have is the door code
Lame ,
Can I get a replacement ?
So you don't have the tag on the firewall?
santa cruz crawler
no tag , it looks like the truck was in a fender  bender , and the tag is missing , there is just holes there  :(
santa cruz crawler
Snowtoy
The tag is on the center of the firewall(back of engine bay below the windshield), not the fender.
With it being an '81 if nobody swapped in taller gears for taller tires, you should have 4.10's.
santa cruz crawler
I am Sure this is where the tag is suppost to be !
And this is where my old tag was in my 1980
Sparkplug
1981 toyotas had dual timing chains and 3.90 gears, not 4.10. They are the only year to have 3.90. Also the only dual chain 22r, and last year of round headlights.
Those are the least desirable ratio, and can be easily identified by a red pinion nut.
84t0y
i believe on 1st gens that tag is on the passenger side inner fender and on 2nd gens it is on the fire wall behind the engine.
Rockdiver
My 82 tag is center back on the firewall
santa cruz crawler
Thanks everyone for the replys , I thought I had 3.90 gears .
When I pull the 3rd ill look for the red ,
There's a link to a bunch of info in the second pOst !!
I have a few extra 4.10 Laying around ! So I will switch it out.
Thanks
blumagoo
To find out what gears are in your truck you can jack up the axle and count the revolutions of the pinion flange to one tire rotation but make sure both tires turn the same speed.
Make a mark with chalk at the 12oclock position on the tire and pinion flange then rotate the tire exactly one revolution while counting the turns of the pinion flange. If it goes 4 turns then to about the 1oclock position then you have 4.10s and if it goes 4 turns then to about 10oclock then you have 4.8s.
I always check this way because in these trucks it's quite common to see altered gear ratios.
81yota4x4
Im glad this post is on here very helpfull guys thank you :thumbs:
LETS ROCK :driving: :burnout:
Quote from: 81yota4x4 on September 14, 2012, 12:30:31 AM
OMFG somebody actually searched before starting a new thread, call out the band get the streamers and banners, glad to see it helped you. :gap:
81yota4x4
Lol it's amazing what happens when people read directions and follow them right :idea:
tgmaul88
im still rollin in my stock 3.90's there still turning
81yota4x4
Me too but I'm running 4.37's which is stock for my truck.
tgmaul88
im running 30 x 9.50 15   nothing big yet,
