2WD CROSSMEMBER
Started by oddball, February 25, 2005, 02:05:01 PM
oddball
I'M TRYING TO GET SOME IDEAS FOR A CROSSMEMBER MOUNT ON MY 85 2 WHEELER. I LIKE WHITETRASHES BUT I HAVE A STOCK 85 CROSSMEMBER LAYING AROUND SO I'M GOING TO USE THAT. ID LIKE TO KEEP IT REMOVABLE LIKE STOCK. WHAT I NEED IS TO SEE PICS OF MOUNTS  OR WT IF YOUR READING THIS PLEASE SHOW ME HOW YOU BOLTED YOURS UP AGAIN. THANX :beer:
On mine I drilled 2 pieces of 1/2" plate in a press so they are all paired up and tapped one plate per pair.  That way I have 8 grade 8 1/2" bolts holding my junk up.  To use a stock crossmember just use square u-bolts over the frame down through the holes in the crossmember.  Easy as pie, Marlin's truck is set up like that.
oddball
WOW  :bowdown:  THAT IS PERFECT! THANX :beer:
