1979 toyota 4x4 questions
Started by 84t0y, May 26, 2012, 12:10:21 PM
84t0y
so i just got a 79 yota a few days ago.
the heater seems to work only on the defrost and lower vents but the dash vents and the one right below the radio is blowing cold air.
how do i fix this? i live up at 5500 ft so heater is important for me.
is there a good write up on swapping manual to power steering?
83 Crawler
Yes search about power steering, and those are the only places heat comes out on thes trucks, the side vents are fresh air
84t0y
so i just have to turn it on recirc to make the cold air stop
gmack192
Turn the Ball (vent ) side ways....... Get under the dash and plug the holes too.
83MT
Also, if you've got it on the defrost setting, only minimal air is coming through those center vents. Where I live it gets down to double-digits below zero, regularly, and my 83 is fine in the winter with no modifications to the vents.
But yeah, keep the side ball vents closed, and block off the center vents if you want.
Mine works for me, though.
Zach
I like Yotatech
ayajei
