22RE Head gasket question
Started by thebigdogg, May 11, 2012, 06:24:05 PM
thebigdogg
I was going back with the head, torquing the head bolts in 15lb increments, you know the bolt up front by the timing chain?
How important is that?
Well when I was torquing it down, it broke!!!  All the other head bolts are torqued, do I have to remove the head again?
emsvitil
You should be able to remove the remains of the bolt without removing the head......
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
santa cruz crawler
Na , I broke one once , if you can get it out then cool but if not , it's not that big of a deal
It might leak a little oil. Idk
toyotanner
probably gonna leak unless your lucky
I'm guessing you torqued it to the same specs as the head bolts?  Probably shouldn't be but 15 ft lbs on it.  I believe it's probably more for holding the timing chaing cover to the head for a tight seal.  You could pull the timing chain cover, remove the broken bolt and put it back together without pulling the head again.
Slolyfe
Easy out and replace, or weld another bolt to it and back 'er out.
You'll never take me alive
thebigdogg
Quote from: kneedownnate on May 11, 2012, 08:48:28 PM
Probably the best solution
Thanks
toyotanner
not quite sure if the timing cover will come off with the head and oil pan torqued....  might have to pull head or oil pan
thebigdogg
I went ahead and pulled the head back off, the broken peice wasn't even tight, i took it out with my fingers
Now i have to go find another bolt
santa cruz crawler
Mabe there is oil junk in the bolt hole ! You need to clean all the threads with air , try to get the threads clean .
