Pictures on how to weld a 3rd?
Started by Volcom, February 24, 2005, 07:50:03 AM
Volcom
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Weldo
Are the spiders and carrier cast metal?  Or are they forged or something?  I'm guessing they're not cast, 'cause a lot of people weld them, and welding cast can be a pregnant dog to do properly.
Like i said before.  I arc welded mine with about 8 sticks.  I am not the greatest arc welder, but i try, i think thats why i put so many sticks into it.  I welded on both sides.  Here is the pic.  It had been sitting in my truck for 2 weeks.
yotaboy79
MidgetMike
Quote from: skinny_pedal on March 01, 2005, 09:45:43 PM
heres a welded 3rd
That's what my third looked like when I was done. Like skinny pedal's
Skinny_Pedal
holy boogers batman! hyena that sure is perty :gap: .
thats not my diff. its a friends, i run a spool
Im an OG
Plowking
Well I can tell you the welding held up till my last job when I got on clear pavement in 4 wd and got a few to many rotations in that b$#@&,  jammed up couldn't get it out of 4 wd, dumped the clutch and jerked it hard to at the next job look down and see the rear not always spinning when influenced with a punch of the throttle. Well got 53 miles out of her and 12 hours of clearing parking lots, and driveways. No adverse sounds coming out of (trucks) ass end yet.
Fronts 4.11 Backs  3.55 im guessing
2008 Dodge Diesel  (Cummins Rule)
6.7 manual quad 8 foot bed H&S delete, banks air box
93 yota 3.0 locked up...
2004 Yamaha Raptor 660R
Plowking
damn Dude thats ugly. I welded mine and didnt pull the gears or nothing If I end up pulling rear out I will post it
Quote from: Hyena on March 02, 2005, 04:08:47 PM
Like i said before.† I arc welded mine with about 8 sticks.† I am not the greatest arc welder, but i try, i think thats why i put so many sticks into it.† I welded on both sides.  Here is the pic.† It had been sitting in my truck for 2 weeks.
bluetoy84
It might not break , but I bet your carrier is warped. Thats WAY overkill. I usually weld about two passes from the side gears to the carrier , more like the first pic. Putting too much weld will warp the piss out of the carrier. When you bolt your ring gear back on it and try to set the backlash you will have tight spots where it has warped the flange that the ring gear bolts to. A good weld is better than a lot of weld , and heat is bad.
I've welded about 15 or so toyota thirds ,and  only 1 has broke. It was an IFS front and the guy was trying to turn it around on pavement when it broke. My :twocents:
vatoyrunner
i had a 3/4 ton with full floating axles... hauled 3500 lbs of sand with ease :) use the right truck for the right job.
It shouldn't be warped.  I welded it when it was still in the third member.  It backlash was fine, but i fried the bearings.  It was a junk third anyway.  I only did 1 pass for each weld, and then i filled up the holes in the corners.  Its not like i went over it 2 or 3 times.
:dunno: if it warps just set it on the lathe and bring it back in
as to the 'hauling"   i have hauled a rick of firewood on my truck stacked tightly front to back, and it was green oak , the stack was 24" widex 4 feet tall x 8 feet long,  i had to put astrap over the stacks so it didnt fall off but i have hauled numerous loads like that,  yea  wheel bearings go, but i usually get 1 year or more out of my rear bearings
toyhatsu
A Daihatsu Rocky/ Feroza third.  Pics from me mate in Oz.
1991 Daihatsu Rocky, 3RZ-fe, Marlin super heavey duty clutch and pressure plate, Marlin W56-C-HD, duals, Marlin twinstick, three link front with Fox AirShox, 35's, Toy axles, 5.29:1, ARB F&R etc.
Volcom
Thanks for the pics, that's a great way to weld the 3rd!
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Yota4life
I had a welded third that someone else welded and they did a horrible job welding and some broke off and got in the teeth and blew up the Ring and pinion. So make sure they are pretty good welds.
