IFS Hub Conversion
Started by 83yota, May 08, 2012, 11:48:27 AM
Rockcrawlintoy
the WMS is different
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
SqWADoosh
SqWADoosh
So found this today: http://www.pirate4x4.com/forum/toyota-truck-4runner/1765073-longer-ifs-wheel-studs.html
Do I need to run longer wheel studs with the taco brake upgrade, or was that simply for that guy's case?
58rag
I did not need longer studs when I did the tacoma rotors. HOWEVER I am running steels wheels. You may need longer studs with aluminum wheels.
OTO Phil
Looks like it just depends on how thick your wheel is..
Mudder
#65
Quote from: SqWADoosh on March 24, 2016, 07:35:14 PM
I figured out a route to take. I am going with 3rd gen 4Runner calipers instead of Tacoma. They have the regular fitting rather than the banjo and have a 15" wheel offering.
SqWA, what backspacing are your rims? Looking at changing from V6 calipers to the 3rd gen in order to ditch the 1.25" wheel spacers due to a rim having at least a 4.5" back spacing
OTO Phil
That's what i have
Sent from my LG-H830 using Tapatalk
SqWADoosh
Quote from: Mudder on October 07, 2016, 10:42:15 PM
SqWA, what backspacing are our rims? Looking at changing from V6 calipers to the 3rd gen in order to ditch the 1.25" wheel spacers due to a rim having at least a 4.5" back spacing
So I'm running 4.25 BS and I opted to utilize 1.5 spacers all around to get out even wider. My 3rd gen 4Runner calipers had to be ground down a lot to clear my 15" rims. This was before running the spacers that is.
xtratoy
#68
I have been reading this and have a 93 with a 4 cylinder. Everything i have read references the v6 caliper. Is there a reason the 22re calipers won't work?. If V6 calipers are needed are any year IFS V6 caliper good or are the Tacoma's better?
gnob
The difference isnt really V6 vs 4cyl.
There are two versions. One has two large and two smaller pistons(4cyl). The other uses 4 large pistons. (V6)
Your 93 may very well have the "v6" calipers.
hold this. . .
OOPS
In 91 or 92 they started using the "V-6 calipers" on all models!!
fasterspider
I put 95 4Runner calipers on a pair of new birthday gift vented rotors on my 85 Hilux long with the proper master cylinder, my brakes work very well. I was going to mount the old discs in the rear but, I do not like the parking brake options that I can afford so I'll just stay with the larger diameter 87 drum brakes on the 87 axle housing in Cecil.
fasterspider, now older and slower.
