I blew a head gasket on my 22re, with a LCE big bore kit and high lift cam. To fix the problem i got a MLS gasket and an ARP head stud kit. After a very light cut on the head, because the MLS gasket requires a very smooth surface, everything went together nicely until i started it and oil was leaking from the valve cover
So I removed the cover and it was hitting on the ARP studs just before the gasket started to compress. I had 3 options, clearance the top of the studs
, clearance the valve cover
, or see if a 20r cover clears. The 20r cover fit and i ran the engine for at least 30 minutes while tuning.
