Author Topic: Catalytic converter sensor  (Read 2762 times)
locked 4x4
  • Male Posts: 466
  • Member since Aug '09
« on: Apr 28, 2012, 10:12:38 AM »
 I have a 1982 toyota pickup with a sensor that bolts into the catalytic converter.  I read somewhere that this didn't have a direct affect on the smog system but was a temp switch to tell if the cat was overheating.  Can anyone confirm this?  I'm putting a new egzaust on the truck and was curious if I still needed the sensor.
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
Re: Catalytic converter sensor
« Reply #1 on: Apr 28, 2012, 11:38:49 AM »
I think you been had
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #2 on: Apr 28, 2012, 01:53:32 PM »
You don't really need it.
My sister's old toyota corona (76) had one of those.
I just jammed it between the cat and cat heat shield when I had to replace the converter. (with a hose clamp so it wouldn't rattle or come out)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Rockdiver
  • Turtle Points: -118
  • Male Posts: 671
  • Member since Apr '04
« Reply #3 on: Apr 28, 2012, 06:29:29 PM »
Its a Thermo Sensor
If the Catalyst is overheated (above 785 deg C or 1445 deg F) ,  the thermo sensor in the catalyst turns off the AI system OFF.
AI  refers to Air Injection With feedback system (Calif models)
All per Factory Service Manual
locked 4x4 [OP]
  • Male Posts: 466
« Reply #4 on: Apr 28, 2012, 11:28:49 PM »
Isn't the air injection system all mechanical?  How would it turn it off?  So is the sensor just a protection system to protect the cat?  Sounds like something that I don't really need.
Rockdiver
  • Male Posts: 671
« Reply #5 on: Apr 29, 2012, 06:41:06 AM »
the AI system can switch the air flow from the air pump to either the exaust ports or the air cleaner in response to the O2 concentration in the exhaust manifold.This maintains the air fuel mix ratioof the inlet gas and looks to be controlled by a the thermo switch (TWC), Thermo sensor 1(coolant)  , thermo sensor 2(coolant)connected to the emissions computer.   The themo sensor on the cat is a safety . So I would do like emsevil and hose clamp it on the pipe if you can.
I just recently purchased a New Magnaflow hi flow cat from 4wheel parts. It it direct fit with flanges and has the place for this sensor. And its Cali legal around 200$
locked 4x4 [OP]
  • Male Posts: 466
« Reply #6 on: Apr 29, 2012, 11:21:27 PM »
Sweet.  Thanks for the reply's.  They told me what I needed to know
Last post Dec 02, 2008, 08:05:03 AM
by RABIDYOTA
Last post Dec 09, 2008, 07:49:59 PM
by Glen1978
Last post Mar 24, 2010, 04:41:08 PM
by joey0712
Last post May 26, 2011, 08:52:20 AM
by yotarunner85
Last post Mar 18, 2013, 05:45:25 PM
by lone walker
