help finding part . were to look .
Started by crazymoritz97, April 24, 2012, 04:34:08 PM
crazymoritz97
hey gals and guys . i'm going to be getting a truck . 79-83 .
the thing i'm looking for help are . input shaft for the t/case the upgrade . the chomely shafts front and rear . the hi-steer what one i need ? that i'm looking to run 35 on it . got front shackles . going to get the rear shackle soon . but what else i going to need . what gears for the axles ? and anything u think i should use ? or mite think on help . O has anyone put on a rear winch on them and the mounting plate ? or how ?
Chris g Moritz
84t0y
Quote from: crazymoritz97 on April 24, 2012, 04:34:08 PM
check marlin for the t case upgrades
you want longfields for the front axle and the rear axle shafts are fine left stock, although you may want to get a ifs(86+) rear end because its 3" wider than the solid axle trucks.
allpro highsteer would be my choice
for gears id get yukon 529s can get them from marlin
other things you will need
shock hoops
ubolt flip
extended brake lines
drivelines
lockers
dual cases
ect
thats the short list
crazymoritz97
i mite just run 33in tire . because i'm don't need the bigger tire now . for what i do . i got a daul t/case for it and front and rear drive line for a older truck i had . front shackles .
Chris g Moritz
