93 hubs on my 80 yota?
Started by Foxx249, April 18, 2012, 06:27:15 PM
Foxx249
I blew the motor in my 93, and it's just sitting in my driveway now on jacks. Bought an 80 with a flawlessly running 20r. Now all that's left is fixing the hydraulic clutch system, all of the lights (headlights, turn signals, and tail lights), and the brakes.
I need to know if it's possible to transfer over the front brakes from my 93 to the 80. I have the complete assembly, but money is a huge issue right now. Thanks guys.
junya92toy
You need to get 1985 landcruiser rotors and might need wheel spacers to clear the bigger caliper
Sparkplug
they should work on the thinner solid axle rotors jerry, but if they are v6 large piston calipers you will probably have to clearance the caliper, or run a wheel spacer
junya92toy
Well he said the brakes off the 93, I assumed he would put the vented rotor on there too, it is better afterall
