90 2wd SaS & 3.4 project
Started by Bradtoyotas, April 15, 2012, 02:13:02 AM
Bradtoyotas
picked up a 90 2wd with a dead 3.0 thought i would try doin a 2wd this time. The plans are to SAS it prolly make my own leaf pack in front chevy 63's rear 85 front axle 92 rear axle.. This truck is a auto so gotta convert it to stick and im just gonna just use the v6 r150 and put a 3.4 in her. So first ive been working on suspension and then ill get to the 3.4 part..
Tonka Toys
Bradtoyotas
#1
1990 v6 2wd  (auto)  :hammerhead:
This is how i pulled it outta the dirt
Before:
After:
Tonka Toys
Bradtoyotas
#2
Got v6 out and working on cutting out ifs and cleaning up frame
Tonka Toys
Bradtoyotas
#3
Got frame cleaned and front hangers mounted And just got rear axle cut off
Tonka Toys
greg_k113
83 Crawler
Finally a new build!! I'll be watching!
Bradtoyotas
#6
So i learned doin a 2wd truck almost requires a complete 4wd for parts picked this up to use transmission,  pedal assembly, cluster, rear axle, rear driveline, ifs hubs for strait axle also kept 4wd gas tank incase im not happy with the 2wd one its a few gallons smaller
Tonka Toys
Bradtoyotas
#7
Todays progress installed IFS hubs with land cruiser rotors and mounted front wheels
Tonka Toys
axled89
i love oregon wheelin.
Zs Confederate Toy
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
Bradtoyotas
#10
Today got power steering box moved and also got it rolling on all four mounted the rear springs using chevy 63 rears got get it all washed down interior and underneath then ill get the 3.4 goin in
Tonka Toys
Bradtoyotas
#11
a few buddys trucks they just gone done solid axle & 3.4 swappen
all of working on our trucks trien to get ready for summers and some lite wheelen trips
Tonka Toys
Zs Confederate Toy
Quote from: Bradtoyotas on April 19, 2012, 09:09:34 AM
Looks like my place when me and the guys get together.
ZACH
87 Rock Rat X
Trail Junky
nisota
awesome build 2wd sas sweeet!  :bowdown:  :beerchug:
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
Bradtoyotas
Thanks!  Its only begun got lots to do biggest parts i gotta find a 3.4 with everything for the right price
Tonka Toys
Bradtoyotas
#15
Donar 4runner picked it up for 650$ Wish i would have got lucky and scored a elocker but it didnt have but it did have 4.10 third member worth keeping after i spent 2 hours trien to get the shafts out of the bent housing
Tonka Toys
Bradtoyotas
Got the oil pan with the rear sump on.. I used the pan that was on the 3.0......wonder why theres no write up on these pans i think there every bit as good as the t-100 pan if not better
Tonka Toys
Bradtoyotas
#17
Got some new rubber put on her
Tonka Toys
Zs Confederate Toy
ZACH
87 Rock Rat X
Trail Junky
Bradtoyotas
Mounted clutch master cylinder and new brake pedal assembly in... Washed interior stripped it down and pressure washed it out. Gonna start on crossover pipe and start setting motor in.. Crossover is gonna be tricky the 2wd frame is almost just like a solid axle frame and its gonna make it tight...
Tonka Toys
Bradtoyotas
#21
Engine bay pics before engine goes in
2wd gas tank works out its level with frame
Tonka Toys
Bradtoyotas
#22
Finally got crossover done.. With this 2wd frame it comes up rite were the flange normally goes and had to get it tight to the motor & trans within a quarter inch wich still only left maybe 3/4 of an inch from the frame rail.. Also worked out good didnt have to add any pipe it all went together well..
Tonka Toys
Bradtoyotas
Got motor all together fuel lines turned around while i had plenium off i noticed it was cracked so put a different one of them on.. But after i got it all done the hood closed without cutting it... This weakend get it wired and started..
Tonka Toys
Bradtoyotas
Tonka Toys
pumkin toy
looks good man, you are making fast progress!
97 4runner Limited
nisota
Oregon wheelin'
82' 2wd-4wd project
Bradtoyotas
#27
Got it almost on the street everything is in except clutch and a flywheel...it starts rite up  and sounds great. Grabs redline real fast not have clutch and flywheel installed....i did a mild build stayed cheap on alot of things but got what i had to to make a good start definetly got do something for leaf back in the front i took a solid axle set and add a bunch of leafs but it works for now.....Need to get it driving and then ill start on bumpers and eventually work on getting dual t-cases the evap and wiring all closed up, so there is no engine light or codes i think builing a 2wd truck has tons of great options especially on front axle clearance bit the down fall is you almost need a whole 4wd truck as a donar..
Tonka Toys
nisota
No armor? Looks really clean good build  :thumbs:
Oregon wheelin'
82' 2wd-4wd project
Bradtoyotas
It will get bumpers sliders and winch eventually just almost outta cash next biggest investment is TRD Supercharger just to give it small block power but stayin toyota
Tonka Toys
