Author Topic: 22re valve noise.  (Read 3964 times)
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,145
  • Member since Sep '08
22re valve noise.
« on: Mar 11, 2012, 11:04:40 AM »
i need some help. iv got a 90 22re in my truck now. when i first start it up it sounds fine at high idle but when high idle kicks down to regular idle i get a nasty clacking noise coming from the head. what could this be? where should i start?
jl93221
  • Member since Apr '08
Re: 22re valve noise.
« Reply #1 on: Mar 11, 2012, 11:26:33 AM »
mine was doing that but not that bad I pulled the valve cover checked the timing chain guides lucky for me they were good adjusted the valves and it helped a bunch
rubiconrunnerneville
  • Male Posts: 89
  • Member since Jan '12
  • I need 37s
« Reply #2 on: Mar 11, 2012, 11:29:39 AM »
check your valves the book says .008 and .012 I have found better performance and a more responsive motor at .007 and .011
ASE certified tech. Cummins factory trained tech.
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • Member since Oct '07
  • low n slow
« Reply #3 on: Mar 11, 2012, 12:47:43 PM »
could just be the injector tick
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
« Reply #4 on: Mar 11, 2012, 07:02:12 PM »
Put a long handle screw driver to the valve cover and the handle to your ear, then do that on the injector, see what one is louder
toyodaaddict [OP]
  • Male Posts: 1,145
« Reply #5 on: Mar 11, 2012, 08:53:42 PM »
i can hear the tick of the injectors firing. the noise im concerned about is louder than that. ill double check the valve adjustment next weekend but ill be suprised if thats it. hope so though
junya92toy
  • Male Posts: 1,500
  • Drinking me beer
« Reply #6 on: Mar 12, 2012, 03:55:42 PM »
Try what I said, it really helps to pinpoint noises
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
« Reply #7 on: Mar 13, 2012, 12:04:54 AM »
my dads had a louder than normal tick. turned out to be a broken valve guide. had to get a new head
UA 342
STEAMFITTERS
hawaiilux
  • Male Posts: 47
  • Member since Oct '10
« Reply #8 on: Mar 16, 2012, 09:37:55 PM »
ive got an 89 rebuilt the head adj/checked the valves 3 times still has the noise its not too bad though and its coming from the front of the cover.  .07 and .11 when cold and .08 and .12 when hot(opp temp)id say to do it when hot.
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • low n slow
« Reply #9 on: Mar 21, 2012, 10:16:38 PM »
timing chain
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #10 on: Mar 21, 2012, 11:29:26 PM »
Make sure the timing chain guides are still there...........  (stock type are plastic POS)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Soviet
  • Turtle Points: -1
  • Member since May '12
« Reply #11 on: May 16, 2012, 01:16:06 PM »
Pull the valve cover, check your clearances and shine down the timing cover to make sure the chain isn't eating its way to water.
Last post Aug 28, 2005, 11:02:15 PM
by toynorcal
Last post Dec 12, 2007, 03:14:09 PM
by OOPS
Last post Mar 20, 2008, 09:38:36 PM
by Skim
Last post Apr 09, 2009, 05:24:41 PM
by BUDDERS
Last post May 12, 2011, 10:48:15 PM
by Magnum Johnson
