Lift From Stock Torsion Bars
Started by Weldo, February 18, 2005, 08:20:06 PM
Weldo
I heard that some of the GM trucks that run torsion bars could be adjusted to get an inch or 2 of lift on the front end from the bars, ya know just enough to level the truck.  Anybody know if the toyotas with torsions bars can benefit from a similar adjustment?
KWP
A buddy of mine lifted the front of his 87 runner by cranking the torsion bars up. I dont know exactly how much lift he gained though.hope this helps ya out :thumbs:
88 Toyota truck ( Under Construction ) Dana 60's front and rear 5.38's, welded diffs, 3inch Downey rears up front,one link rear with aerostar coils rolling on 39.5x16.50/17 Pittbull Rockers and 17x9 Pro Comp extreme alloys.http://board.marlincrawler.com/index.php?topic=40816.0
86 4runner
the most i would crank it up is an inch, if that. it wont ride the same either. i have after market sway-a-way torsion bars in mine cranked up an inch an a quarter and it rides like :pokinit:.
86 4 Runner SAS, 37 inch Toyo M/T's, E-Locker rear, Lock Right front. 30 spline Longs, 5.29's, Dual Cases, Warn XD9000i
Weldo
I guess cranking up the torsion bars makes the suspension a lot stiffer, huh?
Fireimp141
It changes the angle of ure a-arms and makes the ride not so fun, but i got some sway-a-ways and lifted mine about an inch
robinhood4x4
Like others have said, about an inch, maybe 1.5.  Switch to manual hubs if you want to keep your CV boots for long.  Alternatively, you can go with ball joint spacers for 1.5 inch lift.
For the best ride stick with the stock tbars.  Aftermarket bars will make your ride way too stiff and are only needed if you have a heavy bumper and winch.
Quote from: cruzilaWell, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
Weldo
