87 toyota trans swap
Started by old&intheway, February 18, 2005, 05:38:02 PM
old&intheway
The Transmission in my 87 4wd toyota just crapped out and I was wondering what used tranny I could put in it. Can I use a 2wd or 4wd tranny and what years are compatible to my truck. Any help would greatly appreciated. I am assuming I have a G52 or G54 now.
87 Toyota 4WD truck stock w/ 233,000 miles
is it a turbo or non turbo
R151 if turbo,  G54 or w56 if not,  look under the hood theres a label with a bunch of numbers you will find the tranny code,  ie G54, W56 etc.
also your axle codes,  G292 G102   etc
:welcome: to the best bb on the web
hey fatboy hes your neighbor
old&intheway
Looks like I have a G52 transmission code with G292 axle code
cool,  well if you want it to last forever get a G-54 from marlin,  should bolt right in and is a little beefier than the g52
unless you have another tranny available
old&intheway
 I am looking for a used one in my area right now. Is the 2wd G54 the same trans. and what years were they used. Thanks for all the help.
i couldnt say with the 2wd tranny,  guts might be the same :dunno:
have you looked at Marlins
jvministries
here's a suggestion call marlins and ask him they have all the info you can stand
he is the man when it comes to toy transmissions
the 2wd isn't the same I don't think
I had a g52 in mine and broke four of them now it has a later model v6 trans in it
a r151f is an extremely strong transmission and will bolt right to your truck unless it is a v6
the w56
g58
g52
r151f
will all bolt up if it is a 4cyl
but the t cases are different on the r151f's the transfer case has a 23 spline input
some transmissions have the t-case shifter in the top of the t case
others have it in the tranny
called forward shift or top shift
so again call marlin's they can tell you what you have and what will fit and what can be made to fit
and what will be involved with each process
too much spent to go slow
too much spent to stay low
too much spent on the go
but it's fun you know
jr9162
Quote from: jvministries on February 19, 2005, 10:16:54 PM
the w56
g58
g52
r151f
Go with a R151F if you can afford it. Be sure to get the bellhousing and Tcase along with the gearbox (all as a unit). The R151F requires a 23 spline input Tcase, and a different bellhousing than the G52/G54 or W56 uses.
@nd choice is Marlin's W56HD. It'll bolt to your G52 bellhousing and you need to ensure you get the correct Tcase shifter model to match your existing 21 spline Tcase.
JR
I'm a member of P.E.T.A.
People Eating Tasty Animals
There's no nookie like chinookie
No butts like halibuts
Fish are not our friends, they're food.
Eat more moose - 10,000 wolves can't be wrong
Calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed Pharmacist".
