removing leafs from TG springs?
Started by tyes, January 26, 2012, 09:23:36 PM
tyes
how may leafs can i remove from this 5in spring? i already took the 2nd one from the bottom but still too high..
86 T4R V8 1UZ-Fe
86bobbedtoy
they settle!!
flex it up and leave it for a few hours
Cheesemaker
Biggest complaint I've heard about their springs, is that fact that they will settle out bad.  And some even look like a "S" when they are done.
Quote from: tyes on January 26, 2012, 09:23:36 PM
I'd remove all of them and throw them in the scrap pile.
they are made in China,   drive on them they will go from 5 inch springs to stock soon enough
I also suggest reading this thread http://board.marlincrawler.com/index.php?topic=36377.0
IronClad
Quote from: Cheesemaker on January 27, 2012, 07:59:22 PM
Ive seen this with All-Pros and marlin springs aswell. Its not just Trail-Gear.
Annihilation  Fabrication
Do you need a Hammer?
hansi530
i would put that one back in my 4inch hd springs dropped like 3 inches with 1 rubicon run and some dirt roadin
88 custom cab: http://board.marlincrawler.com/index.php?topic=88026.new#new
shitlbuffout-A saying among 4x4 and off road enthusiasts. Its said after damage normally cosmetic to minor parts damage has occurred on there rig or vehicle. Shitlbuffout is :pokinit: will buff out as in the :pokinit: being the damage will buff as in painted over cleaned polished or "buffed" out.
The biggest reason most springs bend or end up looking "S" shaped is the lack of a proper bumpstop. When you build a rig some people don't factor in that if you flex out the main leaf beyond flat you are ruining the springs. Some spring suppliers do start with inferior grade material from unreliable sources but even a good spring will bend if pushed beyond flat. Those unreliable sources are guaranteed to bend in one outing when subjected to this stress and weaken the main leaf giving the feeling it has just settled when you have actually damaged the spring and it will eventually break the main leaf. Quality made main springs will rebound for the most part but eventually they will also bend creating the "S" shape. If your spring settles some that is normal and they should not have any bends of the "S" look, a visible "S" means bent not settling. Flattening of a main spring would be normal settling anything else is just bent. Also any improper removal or addition of any leaf in a pack can actually bend the main leaf too. They were built as designed. If you decide to remove leafs start with the smallest, but one thing to remember is that you want to try to keep the stack even, if you leave longer gaps and shorter gaps you can bend leafs supporting the longer gaps.
Tankard
Bump stops for sure. Some parts become consumables when they take that much stress.
"Knowledge without experience is just information." -Mark Twain
SNOW WALKER
Ha run em. They will flatten out quick. My 3 inch all poops are now -1 inch. I just built some RUF'S and should be way better.
1986 4Runner turbo sas high pinion,E-locked 4:88's,taco rear Detroit locker,22ret forged everything,
duels mc07-r10 cut 42's.
84t0y
does anyone know if the older 3" TG springs are made better? cause I have them on my truck and they are pretty old but they still have plenty of arch and are not at all S shaped. also I dont even run bumpstops.
TimberlineBryce
I took mine apart and added Chevys...
See you at the Timberline!
