87 4runner fj80 front axle in progress
Started by BoG-ToY, January 12, 2012, 05:01:49 PM
BoG-ToY
IFS brackets are in the way, cutting them off tomorrow with a torch.
soon to come will be the fj80 steering box, ballistic coil buckets and probably ford shock towers
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
BoG-ToY
sorry was in a hurry and needed to fix the license plate
John Doe
*** YELLER ***
Is that a time portal you have on the front bumper ??? if where did you get yours ??? I need one for my runner
except BACON
Sparkplug
I can still see the plate?
About time man, bust out that torch and start cutting
BoG-ToY
neighbor said I can use torch tomorrow
only thing left will be the steering box. gonna have to do it without tubes and just bolt on for now
24SHORTIE
why are the pictures so grainy!! but i like ur runner!
BoG-ToY
I took the pictures with my Ipod touch, I can email them directly to photobucket from there.. I dont know WHY the camera on it sucks so bad
BoG-ToY
drove it up and down my driveway:
steering box had ONE bolt, NO panhard, and NO front springs, axle sitting on wood blocks on frame.
Im getting T-G frame reinforcement kit, then welding on steering box and coil buckets, but I am going to set up the panhard before then and probably prepare for the steering box mount
http://www.trail-gear.com/rock-defense-front-frame-reinforcement-kit
BoG-ToY
ok so these are with no lift at all, gotta figure out how high to make it sit while keeping a good castor angle
BoG-ToY
will get more pics tomorrow, need to make a cross brace for the panhard bracket, and need to make a steering box mount
fade
86 mini truck 18" rays
09 highlander
70 suburban
BoG-ToY
just an update, picked up an fjcruiser elocker rear, and some yukons, still setting up, but this is where I'm at and a quote from ZUK @ gearinstalls.com
"You're right....a touch on the deep side but that is what I like to see!!!  :)    Leave it there and 007 BL is the target.  This will favor a touch more strength on the ring which the ring really needs."
pictures of where I am at on the diff build, still needs help. but should have 64.25" wide elocker axle ready to go under the truck by friday!
