toyrover
Started by toyrova, January 08, 2012, 08:19:05 PM
toyrova
here is my land rover going through the stages. Its good thing that i know a few toy members on here as i have been getting alot of help and ideas. but as of now its still in the building stages but as of now it has
6" lift consisting of Early bronco 4.5" springs the springs lifted me higher than expected.
Caster correction radius arms/ longer rear trailing arms.
Fj-80 OME front shocks /Nissan patrol rear OME shocks
Adjustable Panhard bar./ 3/4 ton steering
Tom woods Double cardan driveshafts front and rear.
Custom bulit front and rear bumpers.
rattecan paint job
HID's
in store
Toyota v6 rear diff conversion/with locker with chromoly axles by rovertracks
maybe a three link,im not decided on this yet.
rock sliders
4.10s
heres some photos
yotaneck13
how tipsy is it looks like you could add bigger tires to your list.
kinda unique ive never seen a rover lifter :thumbs: looks good tho
toyrova
thats right i forgot tires haha thanks. it has 33x10.50 right now looking to go to a 35x10.50 Bogger for offroad
its not to tippy. it has a heavy frame and mostly almuinum body panels/except roof  thats galvanised steel!
Yota87Truck
Quote from: toyrova on January 08, 2012, 08:49:13 PM
Oh, is that how those things aren't tipsy!  I always wondered how such a tall vehicle could pull 45 degree sidehills.
toyrova
yeah it definitely helps with the side angles as most 0f the weight is at frame level! :thumbs:
UndefinedTaco
reconigze this rig..you live in northern california?
cool build..
83' Pickup "ShitBox" - more parts
92' Pickup "Doomed" - some parts
toyrova
yes i Do i use to live Fremont now i live in Tracy. and thank you.
46&2
Cool rig. What is involved in using yota axles/gears in the Rover axles? Just clearancing?
Narked
We all crawled before we could walk!
toyrova
Quote from: 46&2 on January 23, 2012, 09:08:25 PM
the rear Diff in the toyota is a stronger carrier for the rover and is already lower geared at 4.10. there is a company "rovertracks"that makes a template to fit the toy diff to the rover housing as both are just about the same size! then the company supplies the custom axles using high strength chromoly axle shafts but the only difference is the axle shafts using a 5 bolt pattern for the rover rather than the 6 bolt pattern of the toyota..
46&2
Quote from: toyrova on January 24, 2012, 02:33:35 PM
Cool, thanks for the info. Always wondered about that.
toyrova
Quote from: 46&2 on January 24, 2012, 02:59:13 PM
no problem
jgeck90
yup bigger tires but nice!
toyrova
looking into getting some 35's in the summer
UndefinedTaco
Yep thought you live in Tracy, passed you on 11th st yesterday...
toyrova
ill look out for your tacoma next time.
whats the specs
UndefinedTaco
im usually in my buddies 86 reg cab..its grey with a yellow flatbed on it
i got a 3rd gen ext cab but im selling it soon to pick up a 1st gen toy pickup..
toyrova
iNfErNaL
Very nice , I like it .
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
toyrova
Quote from: iNfErNaL on February 14, 2012, 11:21:50 PM
Thank you. I like your crawler thats in your Avatar!
toyrova
new Color I just made for the Truck! and its been painted!
kycrawler
looks kind of top heavy any problems on off camber hills.
toyrova
not too bad on off camber hills as the body is mostly aluminum with the exception of a still roof. but most of the weight is in the chassis which is very heavy and that keeps the the weight down closer to the ground. plus i have steelies that are a little wider than stock about 3.75 inch backspacing which allows the track to be widened giving me more stability
toyrova
had to cut out my passenger floorboard as it was rusting.  Im going to weld in a new floor board with all new sheet metal and the have my whole truck interior  xlined.
its cool when your a pretty good  welding student and can fix things yourself with cool student buddies and a awesome teacher.
