installed a new clutch and now its slipping only after 4x4 double low on the dual transfer case. it has new flywheel, pressure plate and throwout bearings. this kit comes with everything already resurface. when i do drive around town it will not slip one bit and drives as it would. after 4x4 it begins to slip on and pulls really slowly... here are some specs that is related to drive train: 86 runner SAS, dual case 2.28x4.70 (MC), 55k mi 2wd motor, 5.29 f/r, ARB f/r, 38.5 SS sx. please help! thanks.
hhmm, i do believe there is more torque in lower gears and torque will cause the clutch to slip before HP, look if you are Toyota guys and know the 22re, you slip a brand new clutch in 4th or 5th, you need to start looking at installation mess ups.and that the stock clutch was never meant to have a double down low load attached to it.the other problem he might have is a miss adjusted push rod on his clutch, or if he has a master cylinder from a cheap auto parts store it might not be releasing his clutch all the way, but your torque is going to spin the clutch before your 4th and 5 th gears just driving down the road.
I agree with Glen...There's more load on the clutch in High range with the trans in 3rd or 4th than in any of the Low ranges in the T-case. It's just isn't possible that the clutch would slip in low and not in the high ranges while street driving....UNLESS, you're referring to downhill descents in low with no throttle input and the vehicle could move faster than the engine can brake via the clutch.and just to clarify....Manual transmissions don't slip, clutches do.
Then maybe you can explain why it is that I have a stock clutch with nearly 100K on it with duals and lockers without slippage of any kind. When you shift gears, everything in front of the component where the gear shift took place has a reduced torque load on it. Everything after the component where the gear shift took place has an increased torque load.If your thinking is true then you should have no trouble taking off in 5th gear and not even smoke your clutch.
what clutch you runnin?
Is the clutch pedal adjusted right?
Started by wrenchtech Engine
Started by Weldo Toyota Pickup/4Runner Tech 1979-95
Started by rclang72 Toyota Pickup/4Runner Tech 1979-95
Started by Stubs Engine
Started by dtc81 « 1 2 » Transmission/Clutch
