V6 Gears in a 4 Cyl. 3rd Member?
Started by 1Bad4Runner, February 16, 2005, 10:23:08 AM
1Bad4Runner
Hi, I was just wondering how you can put the gears (ring and Pinion) of a V6 3rd member into a 4 cyl. 3rd member?
Do you need to change the 2 pinion bearings and races? I already have the ring on. :headscratch:
firekiller
#2
http://home.4x4wire.com/erik/diffs/#rear
http://www.pirate4x4.com/forum/showthread.php?s=6995b2bae6af70a385eaea09f03f307b&t=173918
Hope this helps.  A lot of good info to be had.
Tico
:beerchug:
Sorry for the redundancy of links.
Tico
Skinny_Pedal
pinion bearing is smaller to make up for the larger ring. i have ther part # at home
Im an OG
1Bad4Runner
Ok, the links helped a little... I just called a parts store and asked them and they told me that the bearing from 79-88 or something is the same and from 88-94 there was a different bearing.
The lady gave me all the dimensions of the bearing and I have the smaller one I think.
Here are the specs I found.
From 79-88
ID - 1.378
OD - 3.15
Width - 1.1635
Newer with 3.0 L engine.
ID - 1.378
OD - 3.503
Width - 1.5055
The one with the 3.0 L is larger, not smaller. Does this sound correct? I looked that the two pinions together and they are the same length all together, except the sleeve spot for the inner pinion bearing is longer.
1Bad4Runner
#5
Heres what they look like next to each other.
Any ideas?  :confused:
