frame tubes
Started by Michael Wollinsky, December 13, 2011, 06:47:19 PM
Michael Wollinsky
How big of hole do you cut in the frame what size? I'm going to use a cutting bit
Hand built and driving daily
socal 88
What are you cutting holes in your frame for? :flamer:
Sparkplug
iirc 1 3/4, ill check my jigs tomorrow. I know that some frame tubes have a larger od than others. Where did you order yours from?
Michael Wollinsky
I ordered from trail gear I know I don't need to be bashed but on the east coast where I'm at there isn't  many trails and I'm flat broke in high school and work one day a weeks
yotaneck13
i tried to use my holesaw set but it wouldnt cut through my frame i just set up my jigs and traced them and torched away came out nice check my build trhread one of the last 2 pages its in my sig.
Where at on the east coast you from?
Michael Wollinsky
Sparkplug
trail gear actually sells good tubes, other vendors sell worse, trust me
Ive done it with a holesaw, and with a torch, both have their perks. Are you doing it with a 1/4 inch rod inside the holesaw for guide, like shown on pirate4x4?
hansi530
 i used a 1 3/4 hole saw for mine and it worked great
88 custom cab: http://board.marlincrawler.com/index.php?topic=88026.new#new
shitlbuffout-A saying among 4x4 and off road enthusiasts. Its said after damage normally cosmetic to minor parts damage has occurred on there rig or vehicle. Shitlbuffout is :pokinit: will buff out as in the :pokinit: being the damage will buff as in painted over cleaned polished or "buffed" out.
Michael Wollinsky
 i got the jigs and just a regular hole saw
Sparkplug
grab some 1/4 steel rod, dril a 1/4 inch hole dead center of your hole on both side, stick rod into middle of holesaw, stick in and will guide your cut and make it 10x easier on you
Michael Wollinsky
SloCrawler
I have a pair of tubes and jigs never used $20 shipped
