newbie here tcase ?
Started by 2 feathers, December 05, 2011, 06:03:55 PM
2 feathers
im planning on putting dual cases and had a few ?'s can you use a 21 spline crawl box with a 23 spline 4.7 tcase. And do you see a need to do a 10 degree rotate. Im putting a high pinion in the front. Does the rotation effect the mount and crossmember you can use.
yotaneck13
not sure but wouldnt the 4.7's be in your crawl box? with a stock front case? as for the 10 deg rotation that is for ground clearance it rotates the case up into your frame rails and will affect drive shaft angles . most people do this if theyre trying to completely flat belly their rig
daniresch
You can use a 21 spline crawl box with a 23 spline 4.7 tcase. And many people do, you will be using a 23 spline adapter.
The rotated adapter rotates the tcase counter clock wise 10 degrees, lifting up the front drive shaft and gaining 1 3/16" of clearance. It does effect the cross members you can run. I know FROR makes crossmembers for a clocked adapter, i am personally running theirs now and have been very happy with it. Another thing to consider is your shifter will be angled on the back case if you use a regular shifter, there are twin sticks built for clocked adapters, or triple shifter is also an option. The tcase and driveline clearance is a big bonus and i do recommend getting a clocked adapter.
As for what yotaneck13 said, 4.7 is not in the crawl box.
2 feathers
Thanks for the great info daniresch. what are your thoughts on the triple shifter ide like to have a small console between my bucket seats. my 88 reg cab needs all the room i can get inside.
daniresch
I have a reg cab as well with a bench seat, the triple shifter clears everything with ease. I am running Davez triple shifter with no problems, along with a clocked adapter. Very happy with both products. I have pictures of both on my build.
daniresch
2 feathers
It looks as though we are building the same rig. I have my sas kit coming from dave. Ill bring up some pics when i get a few more posts and farther along. Thanks for the great info. I really like the looks of that crossmember. Dumb question but who is FROR?
2 feathers
yotaneck13
:smack: mybad i have no clue where my head was there lol
2 feathers
no worries yotaneck13  :gap:. any progress on your project?
yotaneck13
some i have been working on a toyota rear steering axel but everything else is in storage till i get some parts built up
