sas'd 1990 pickup
Started by superyota, November 30, 2011, 10:05:32 AM
make a new filler neck and have it hook the stock fuel door?
superyota
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
suprawheeler
85 4Runner powered by 7mge,W56 trans,dual t-case, 5.29 gears and Toyota E-locker front and rear, Longfield 30 spline front axles and chromoly hub gears, Front Range full float rear axles, Tundra front brakes, v6 calipers and FJ60 rotors on rear, t-case e-brk, 6shooter knuckles with trunnion bearing eliminator kit, Stage 8 locking spindle nut, 41x14.50x16 Swamper Iroks.
superyota
Thanks! Credit for the tube work goes to my buddy mike in bajersfiekd(gfab).
ABD Motorsports
#4475
KK6QDW
John Doe
What was used for the trim around the cut fender lip?
superyota
A roll of vinyl trim from auto zone. Worked out pretty good.
ABD Motorsports
#4475
KK6QDW
superyota
ABD Motorsports
#4475
KK6QDW
mudaddict
I like the sticker on the frame  :biggthumpup:
truck looks good man.
I work At
All Pro Off Road
superyota
ABD Motorsports
#4475
KK6QDW
superyota
#39
Well, the front and rear axles both blew during mcr this last weekend. Broke a front ujoint and the ears off both outer and inner on the 10 bolt, kinda expected. Also broke a 1310 ujoint on the front driveshaft. On the way up Cadillac the rear end blew and sent pieces of the welded up carrier out of the rear axle housing.
My dad and uncle after a rough ride up Cadillac.
I need to build this thing to where my dad can wheel it without worries of axles breaking. I need some input...
I have 2 options here, go with built toyota axles(30 spline longs, spool rear, arb front, etc), or.... Go with Dana 60 front and either a Dana 60 rear or 14 bolt, geared and spooled rear/locked front.
Both the front and rear axles are toast right now so it's all coming out. Planning on getting new axles under it soon.
ABD Motorsports
#4475
KK6QDW
NorCalPR
Eddie, if you need someone to install the gears, I can do it pretty cheap. I won't use peanut butter ;)
I say fj 80 front with Billy's outers and a solid v6 third for the rear
"W6FTW"
superyota
Thanks Phil! I'll might take you up on that offer as soon as I figure out what setup to go with.
ABD Motorsports
#4475
KK6QDW
bigarms23
id say a front ruff stuff 609 and crusier 80 ruff stuff rear than your dad can have removable 3rds but depends on the budget
superyota
Picked up leaf spring v6 rear complete and also a complete 85 front axle last night. Both axles are bone stock. And for the rear are a spool and 5.29s. Plans for the front are 5.29s, grizzly locker, 30 splines, chromoly hub gears, arp hub and knuckle studs, and hysteer. Hopefully this takes care of all the issues. I think that will be a pretty bullet proof setup.
I still need to weld up a new front hanger.  Should have this thing rolling again in the next month or so. Going to fully build both axles first then mount them up. Pics will be up soon!
ABD Motorsports
#4475
KK6QDW
NorCalPR
:smokin:
I'd also rec the 25mm setup to keep the trunnions in check with those heavy tires. I was going thru trunnions left and right till I upgraded
"W6FTW"
superyota
Yea, I forgot that part. Adding 25mms to the list.. Thanks phil
ABD Motorsports
#4475
KK6QDW
NorCalPR
Sweet! Let me know if you want me to do the diffs. Maybe me and Erika can go to old sac one weekend and we can meetup so I can do them a following weekend.
"W6FTW"
superyota
Sweet. I might take you up on that offer.
ABD Motorsports
#4475
KK6QDW
superyota
Ordered up all the parts yesterday. 30 spline bobby longs and chromo hub gears shipped today. Also got lots of goodies from Marlin Crawler, 5.29s, spool, grizzly, 25mm, hd gusset, rebuild kits and more....thanks Marlin, Big Mike, and the rest of the Marlin Crawler crew for great customer service and top of the line products.
Pictures of the build up will be soon to come.
ABD Motorsports
#4475
KK6QDW
TacoRunner
Looks like someone needs a Diamond. Nice carnage!
www.4WHEELUNDERGROUND.com
[email protected]
superyota
Finally started taking apart the axles I'm building up. Had to move my truck out of the garage and to the back to make some room...
More pictures soon to come. I'm hoping to have both axles fully built to where I can bolt them up and fab the new front spring hanger next weekend.
ABD Motorsports
#4475
KK6QDW
superyota
Haven't updated this in a while....
ABD Motorsports
#4475
KK6QDW
superyota
ABD Motorsports
#4475
KK6QDW
superyota
#53
I just picked up a new cv drive line from sac drive line. Need to install rear drive shaft and do a bit more finishing up and it's ready to test.
Future projects are to do a walk through cab, fuel cell, cut down the stinger and make it shorter, and add a rear seat with family cage.  Hopefully it will all be done before the end of summer.
ABD Motorsports
#4475
KK6QDW
kdub0013
When is the shakedown run of this hog?
superyota
Hoping to have it out for our next rock move ;).  Ill keep you posted.
ABD Motorsports
#4475
KK6QDW
kdub0013
Sweet sounds good. Makes me miss my rig and it's 2wd fenders. Now it's all hacked up.
superyota
ABD Motorsports
#4475
KK6QDW
NorCalPR
Lookin sharp with those racelines
"W6FTW"
jrock
