Geezz... those Viper towers look like they are built for some very serious abuse!!As I watched over the years the guys redesigning and replacing the parts that failed on the trails... here in AZ mostly serious rockcrawling.... they would strengthen one part only to transfer the energy to a weaker part. What parts do you see potentially becoming the part that will possibly fail? Or does your build design reach a point of almost no chance for a structural failure, or weak link in the chain. I'm just curious.During my sand railing days, the guys figured out quickly that a "weak link" was a better option, and decided, for example, they could change a low cost clutch disc in about 30 minutes. However using the heavy duty feramic disc would eliminate clutch slippage, but the solid hook up also took out transaxles, which was costly and took about 3 hours to R&R. That's when some went to the low friction clutch discs and higher clamping pressure plates. So if they smoked a clutch disc.. it was typically a quick and less costly fix in the dunes.Gnarls.
Great build and an inspiration for what I'm doing with my 89 extra cab. Did you get the 3.4 installed yet and if so are you running the exhaust on the passenger side? Do you have any interference with the upper link and the exhaust? I'm asking because I have a 3.4 that will be going in place of my 22re soon. I have all the IFS removed from the frame is cleaned up ready for plating so the suspension is not installed.I have read on install instructions that on a swapped 2rz, 3rz or a 5vz the upper link in on the drivers side. Did you have to relocate yours or did you leave as you had it for the 22re?Thanks,John
Nice score on the transmission. I suppose it will be nice to be able to use 1st, 3rd & 5th.
Need to move forward so...... Finally stooped to my low and bought a Trail Gear Adapter ECGS had the best price and shipped same day. https://eastcoastgearsupply.com/i-135580-toyota-v6-transfer-case-adapter.html
Can’t blame you. I think Advance Adapters also sells an R-150 to RF-1a adapter.
DAMN!!! I am a slackerNow, don't get too excited. I don't have my 3.4 in, or my rear diamond- cuz i SUCK. Too busy putting my life together last couple.BUT- i did score a freshly rebuilt R150 trans. to use instead of my R151. The R150 has a longer bell housing and keeps the shifters in the same location as a 151/22re combo when swapping to the 3.4. A 151 trans would mean cutting 4"forward into the trans hull and the transmission shifter comes up into the center console at the radio. Not cool.So, one more biggie in the bucket. Hope to get to it soon - ie this summer. anyone know Joey? He's my hero of the day.
