just purchased an 87 4runner
Started by 12 valve, October 16, 2011, 08:10:44 AM
12 valve
I hope this is in the right section. I just picked up an 87 4runner that has been sitting for the last ten years. I'm just not sure where to start on this the motor is in pieces in the back its a 22re with five speed.
Rockdiver
get a factory service manual . i believe there is a link somewhere to it . and start to rebuild it . engine builder has kits .  Good luck
you might be better off getting a used engine thats complete, and a Haynes manual so you can see where all the hoses go.  before you ever try to start it drop that gas tank and remove the sending units and fuel pump and drop a few feet of tow chain in and shake it till your arms are rubber to remove all the rust thats accumulated over the past 10 years
12 valve
Ok the motor is missing a lot of the bolts I think I might try to find a donor truck for parts.
yotajohn
ya a donor motor is one of the best easiest ways to get started on a fun build good luck and keep posted with build
12 valve
