Problems with All-Pro trans brake
Started by Seeds, October 12, 2011, 09:42:30 PM
Seeds
Anyone experience this problem.
I have an 85 4runner with no body lift and an old Marlin crossmember. The trans brake rotor hits the bottom of the body. Since I dont want to lift the body and I'm not gonna drop the tranny, i had to cut a slot in the tunnel to clear it and move the fuel return lines out of the way. Since I am runnning stock tranny and engine mounts, it was a pretty big slot. Happens to land right where my seat mounts are, weakening them.
Thoroughly disappointed I called all-pro and they said they've never had this issue and dont know what I'm talking about. They install and sell them all day to trucks exactly like mine yadda yadda. Acted like I was retarded who knows, maybe I am.
Also, anyone know why you would design a tranny disk brake system where only 2/3 the pad contacts the rotor?
Plus the whole unit bolts to the transfer case and while the bracket for the brake is 3/8 steel, if I were to slam it on a rock it would probably crack my t case.
Otherwise, it'll hold my truck at 45 degrees no prob. Way better then the e brake before. Just cant run it with a rear DS disconnect :)
Romans 12:2
4RunnerChevy
When I had mine installed it used all but 1/8" of the pad.  When you need new pads look me up I have new replacement liners.
Seeds
Quote from: 4RunnerChevy on October 13, 2011, 06:02:37 AM
good to know. I will!
Romans 12:2
Slolyfe
#3
Yea. I have never been happy with mine. cant wait to get rid of it.
Also a MUST. You have to run solid motor mounts on your engine. Because your tcase mount has no give and your motor mounts do. I have cracked 2 housings before I figured this out.
You'll never take me alive
Seeds
? i am not sure why you have to run solid mounts. My trans brake mounts right to the transfer case.
It should move where the transfer case moves correct? Are you sure you didnt smack the assembly once or twice? Thats my fear.
Romans 12:2
H8PVMNT
I think he's running the one with the ebrake on the new t-case crossmember that bolts to the rear of the case and the onto the inside of the frame rails, not just the ebrake bracket like you have.  I have the one like you have and I love it.
– Steve McQueen
Seeds
Quote from: H8PVMNT on October 19, 2011, 08:18:27 AM
i see. then that makes sense. no wonder it cracked. sheesh, id ask for my money back and a new t case if i had that kind.
mine is like the pic, the brake works great. ive been on 45 degree plus inclines and it held solid, but didnt like the install or the potential to take a big hit and crack your t-case. i may have to do some redesigning
Romans 12:2
Slolyfe
Yep. Poor design. Sorry, I thought that is what you where talking about.
