toyota knuckles
Started by zebracrawler, September 16, 2011, 08:27:48 PM
zebracrawler
how do i know if my knuckles are aligned if i do not have a alignment tool on my Toyota axle  :dunno:
sas 85 2wd dual cases locked rear 35s
http://board.marlincrawler.com/index.php?topic=81775.0
BadnewsBob
I would like to know the answer to this myself....Them tools are pricey.
AE2 USN ret
No matter where ya go..... there ya are.
Hillbilly Offroad
84 xtra cab on 63" chevies and RUF 35" KM2s 22R 5 speed DTC 5.29s Locked front and rear.
Fiercefirstgen559
I've been told that as long as you use the same amount of shims, top and bottom, it should be close. That's how mine is setup and my seals are holding great. I don't plan to use the tools
I don't gas my toy after midnight, I treat it like a Mogwai
Cuz it will turn into a gremlin and run over kids, women and men. VRRRRN! VRRN!
zebracrawler
yeah  that's what i did i looks to be aligned ill see if my berfields are grinding in the knuckle when i turn if so then i need to fix it wonder how much toyota charges to have it done
1980yota
On mine I just put the same number back on top and added shims into the bottom until the slack was gone. I think it was roughly the same number of shims top and bottom though, however I dont remember how thick each shim was.
Wermz84
You will never know unless you properly align it, there are other methods without the factory tool.
Do they leak now?
I like to Drive!
