Got propane
Started by 83 Crawler, September 15, 2011, 11:30:00 PM
83 Crawler
GNasty 82
I am and I love it.   :driving:
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
Quote from: Toymin8r on July 19, 2010, 02:18:05 PM
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
83 Crawler
i hate carbs so propane is amazing! the only sucky part is taking it in and out when filling but o well
how do you mount your vaporizer?
GNasty 82
I made a bracket and mounted it on top of the fender well.  Looking back, that was actually the most difficult part of doing the conversion, but not because of inability to mount, but the tube that goes between the regulator/vaporizer and the carb that was supplied was too short, therefore limiting where I could mount it.  I should have purchased a longer tube and I would not have had any problems.
As far as removing the tanks go, I have a custom bed and a mounted the tanks in such a way that they can be filled while still mounted on the truck.
  BFG 37" KM2s
  Propane Powered.
Build Thread:
83 Crawler
What year truck is it on?
GNasty 82
  BFG 37" KM2s
  Propane Powered.
Build Thread:
83 Crawler
Duh! Lol can you take picture on how you mounted it in your engne bay
GNasty 82
Once again, see the sig.  :yupyup:
There's a picture of the original setup, which is pretty close to the way it is now, just shifted and rotated slightly.  In the position shown in the picture I couldn't mount the filter, so I slid the regulator and mount closer to the firewall and rotated the regulator 180*.
Forgive the nastiness that is the old emissions crap, all that has since been removed (propane doesn't need it and no smog in AL   :biggthumpup:)
Quick link to the post with the picture:  http://board.marlincrawler.com/index.php?topic=64521.msg793418#msg793418
  BFG 37" KM2s
  Propane Powered.
Build Thread:
83 Crawler
haha i guess i just dont see when i should lol ill read threw it, thank you  :beerchug:
83 Crawler
the pictures a a little hard to see im just trying to figure out a good way to hold up the vaporizer on my 83
GNasty 82
I'll try to remember to snap a couple after work today.
  BFG 37" KM2s
  Propane Powered.
Build Thread:
83 Crawler
alright that be cool, how did you lock tight the idal screw?
GNasty 82
#12
I think the instructions call for you to crimp some threads on the old gas carb idle screw.  I like that idea, so i just adjusted it to where I needed with blue locktite.
As for my bracket, I just used some 1"x1/8" flat bar.  Also, if I remember correctly, I wound up not even drilling new holes, I drilled the holes in my bracket to match some holes that were already there and left over from where I removed some emissions crap.
  BFG 37" KM2s
  Propane Powered.
Build Thread:
83 Crawler
thats a good idea, sweet thanks, but ya a picture would be helpful to, thanks  :thumbs:
GNasty 82
No problem, I'll try to remember to snap some.
  BFG 37" KM2s
  Propane Powered.
Build Thread:
GNasty 82
Some pictures.
  BFG 37" KM2s
  Propane Powered.
Build Thread:
83 Crawler
Thank you that will help alot,
