backfireing
Started by phlatbed, February 08, 2005, 05:12:11 PM
phlatbed
ok so my truck has had some HUGE backfires lately and it is coming from the exhaust, what could it be? ignition timing, or carb? or.......?
sounds like you need to advance your ig timing ,  could have a cam retarded too much
scheid6996
well it depends on a few things, but the rule of thumb is if it comes from the carb, its retarded, if its advanced its out the exaust, when does it back fire? like on deccellaration? if so thats an exaust leak
When i die, i wana Be buried face down, so anyone who doesnt like me can kiss my :moon:
Its a redneck thing
"Nobody Loves Me"
WHITE_TRASH
Yup if you have even a pin holeahead of themuffler you will get a wonderfully LOUD bang on decelleration.
phlatbed
yah it happens when down shifting and slowing down
Willy Mammoth
Almost sounds like valve timing. If you don't have any exhaust leaks I would check the timing chain to see if it has streached. How many miles do you have on the engine?
phlatbed
theres about 211,000 on it, runs extreamly stong just the occasional backfire
scheid6996
i dunno thats alot of miles, my 4 banger blew on me after 150,000   but thats mostly my right foot,  umm ya check your exhaust, and wut R u running for a muffler, cus like a cherry bomb will back fire no matter wut you do
Its a redneck thing
"Nobody Loves Me"
you know shaving a head will actually retard the cam,  thats why i always install mine straight up, this way my cam is actually retarded a degree or two,   this gives better lowend ,  i bet his chain is stretched enough that his cam is actually retarded 3 or 4 degrees causing a little fire to escape at the end of the power stroke
scheid6996
ya that could be, i wonder if he has a loud knock when he starts it in the morning, cus usually thats the timing chain being loose, and even when its that loose i havent had it back fire, but ya it could be, espetually since he has like 200,000m  on it
Its a redneck thing
"Nobody Loves Me"
yep, trust me mine had 285,000 on the original 20R when i tore it down,  but it could have gone longer but it was tired
phlatbed
no loud knocks in the morning, i am going to check the timing chain this weekend, and its just a normal toyota muffler
DAWGTOY
hey man
check your exaust system closely, it could be a blown exaust gasket or like wt said (even a small pin hole ahead of the muffler will cause a backfire). mine did the same thing, replaced the exaust manifold gasket and it still did it took some searching but found a small crack in the head pipe where tha two pipes go into one, welded up the crack and vala no more backfire.
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
scheid6996
is it a very loud back fire? like one gig bang, a a few small banks and pops?
Its a redneck thing
"Nobody Loves Me"
chains about to brake,  has effected ig timing
scheid6996
ya maybe, but iv never had that happen b 4, iv hadem get so loose that they chatter under a load, but they havent fucked with the timing
Its a redneck thing
"Nobody Loves Me"
phlatbed
scheid6996- its all just one huge bang
scheid6996
ya it could be the timing chain, but thats alot of work, so B 4 u do that, id check your timing, how many degres it is, and wut do the plugs look like, beacuse if your running fat on the fule and retarded on the timing, you can get a backfire, but it does sound like the timing is off, but i havent had that problem with out the chain being hella lose and when its that loose when u first start your truck it will slap for a lil bit, and under a loal it will slap also
Its a redneck thing
"Nobody Loves Me"
is this all the time, or just when you downshifting???? aka slowing down???
scheid6996
no, just when i was going up a hill, and i never had it back fire
Its a redneck thing
"Nobody Loves Me"
phlatbed
Quote from: Glen on February 10, 2005, 06:27:50 PM
down shifting aka slowing down
Willy Mammoth
Somthing I just remmembered, If you drive down the road at speed and turn off the ign and hold down on the gas ( carb model only) and turn the key back on it will explode your muffler. So if you are down shifting and you are running rich you may be filling your exhaust with gas fumes that will egnite with a stray spark or heat sorce from your engine.
ezthere
before you adjust anything stick a timing light on it. If you can, get a vacuum gauge and plug that in..
Next consult a detailed manual. Chiltons, there ok. If you can get toyota or better yet go down to the toyota dealer and ask them to print you material,,, :beer: there kicking in.. :haha:
Ask the dealer to print you a service manual referance. IE timing, vacuum & a TROUBLE SHOOTING guide.. They have them.
TRASH what up  :_oops:
Chuck
Chuck
scheid6996
see how everyones leaning away from the timing chain, like i said  haha
Its a redneck thing
"Nobody Loves Me"
