1986 built toyota crawler
Started by poor boy pulling, August 28, 2011, 07:39:35 PM
poor boy pulling
SAS in the front with 3 link, fox 2.5 16" air shocks
alpro leafs in the rear inboarded with a swinging shackle.
ARB front with 5.29s all ARP bolted and rear spooled with 5.29s
22re, 5 speed and dual stock cases
dual case cross member cut to almost flat belly and 3/4 inch thick on bottom
longfield super axles inners and outers with hubgears
.250 wall Drivelines with CV front
front and rear have been doved and rear is bobbed
full exo
38.5" TSL SXs with 36 bolt rock stomper beadlocks 75+% tread
LED rock lights
viaair HD pump and 2.5 gallon tank for OBA with gauge and switch
hydro assist not installed but brackets are there
SCAT procar heated seats
new water pump and coolant hoses
new gauges coolant,oil, and volt,
engine was resealed by the PO with new head gasket as well
new toyota clutch
electric fan with switch in cab ( truck never gets over 180*)
hysteer with IFS box
CD player, will throw in (2) 12" kenwood subs and amp for the right price
truck travels 50"+ with forklift and works amazing
the bad
has an exhaust leak
power steering pump wines, still works fine
needs a top made for the tranny tunnel with shifter boots.
needs another rubber bushing bolted in  for tcase( have the rear spine if wanting to go that way as well)
its an awesome truck but im looking at getting out of crawling so this has to go. looking for 5000.00 OBO more interested in prerunner, quads, other desert toys, other crawlers let me know what you got. thanks
poor boy pulling
forgot to add it has a new red top optima and ruff stuff battery box
Dirty D
ghetto
