L52 tranny problems
Started by tlindzyota, February 07, 2005, 03:35:41 PM
tlindzyota
I'm trying to  troubleshoot my tranny problem before I start taking apart my truck.I was driving home and heard a load clicking sound from the tranny, next thing i know theres a hard core grinding sound and i was a sitting duck. Tried to put it in 4x4 thinking it was the thrid member but sat there grinding. If anyone any clue where to start it would be most appreciated.
Saving for a fj-40!
does the drive shaft turn???       does it feel like its going into gear???  was it making a roaring sound  previous to this??????
tlindzyota
The front and rear drive shafts spin fine, i thought it was my rear u joint because it has been making squeeking when i put it in reverse. It went away a few of days ago. I also found a worn motor mount.
Saving for a fj-40!
tlindzyota
Also its grinding when put it in gear, the only problem i had previous i that 5th gear grinding, but i heard that has always been a problem with the L52
Saving for a fj-40!
tlindzyota
would it help to know that it came home via towtruck
Saving for a fj-40!
um where are you??   yep sounds like its toast, wanna sell it as is???
tlindzyota
found the problem, i took it apart and found that it was the throw out bearing. I might be interested in selling it, I'm out here in Santa Cruz Ca. Is a 82' LB, 170,000 miles,3 inch lift,33" swampers,32/36 weber, magnaflow exhaust. Passes smog like a champ. open to offers.
Saving for a fj-40!
