tranny?
Started by shifter, February 06, 2005, 01:05:45 PM
shifter
ok guys im finley geting rid of my auto  :biggthumpup: . my buddy just gave me a 5spd and case for 100$
what i need to no is what do i have to buy to complet the swap? also should i go a head and buy the 4.1 or dule case ?
spec.
85 runner
5.29
4cyl
Jeeps are like tampons , every pu$$y  needs one.
If you got the $$  go on and get your dual case setup , otherwise you may have to do drive shaft work twice
you'll need to go to a junkyard and get a clutch pedal and get a clutch master cyl and slave cyl
You'll need the pedal assembly, clutch master cylinder, clutch hardline and soft line, clutch slave cylinder, flywheel, clutch assembly and a butt connector to connect the neutral safety switch wires together so it'll start when your done. :gap:
